Old 03-03-2009, 05:47 PM   #1
worknprog.99
worknprog.99's Avatar
real fast
what color are the rear speaker wires that come out of the stock radio?
Old 03-03-2009, 05:58 PM   #2
Valley olds
Valley olds's Avatar
light blue and dark blue rear (passenger side)
red and black front (passenger side)
At least thats the color wire the speakers get, not really sure how it comes out of the stereo. Also mines 04, dont know if its different for yours.
Old 03-03-2009, 05:59 PM   #3
worknprog.99
thanks man much appriciated
Old 03-03-2009, 06:03 PM   #4
Valley olds
No prob. If you want to know about the driver side, just pop the trunk and look under the rear deck to see what wires get to that speaker.
Old 03-03-2009, 06:31 PM   #5
worknprog.99
thanks man also. how do you hook up an amp and one sub? i have the amp the sub and the wiring kit
Old 03-03-2009, 06:51 PM   #6
Valley olds
you wire the red power cable all the way to the battery. Ground to a metal (I used one of the bolts from the struts I think). And remote to the left of what I think is the wiper fuse. Only 25 amp small fuse on the driver side fuse box. If you have an after market hu, just wire the remote to the remote wire in your hu. For your signal, if you have an aftermarket hu, just connect the rca's between that and the amp. If you have stock hu, use the high level inputs (little harness with 4 wires that comes with amp). What you do for that, is splice the wires from the 6x9s in the back and make the connections there.
Old 03-03-2009, 11:25 PM   #7
worknprog.99
well i got everything hooked in and was putting in the inline fuse on the power wire and i accidently f@#$kin broke it so i have to wait till tomorrow to hope i can find one to finish installing
