Old 03-03-2009, 07:58 PM   #1
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Need help running wires
gonna run power on the drivers side, rem rca and remote on the passenger, i know how to go under the rear sead and get the panel up on each side, i dont know how to get teh wire underneath the post were the seatbelt is atached to in between teh doors or how to get underneath the front panel,
any available pictures would be great on where to pull and pry on
Old 03-03-2009, 08:05 PM   #2
our cars are like cheap snap together models. grab a corner/seam thats showing, and pull up on it. you'll hear it pop free. slide your hands down further and pull again.
eventually, you'll reach a spot where the other side will come free. WHA LA! you've removed a piece.
the back panels are more of a pain then the ones under the doors. but repeat the same steps. everything is snapped into place, so it just unsnaps when pulled on.
although AVOID pulling it at a weird angle. (don't like.. grab the panel under the door, and just try yanking the whole thing out from one end. when you hear one clip pop free, move down to get the next, don't keep pulling from the front. plastic breaks at sharp angles)
Old 03-03-2009, 10:34 PM   #3
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i got the rear, ill try the front agian like that but i dotn know aobuot the center of it
Old 03-03-2009, 10:41 PM   #4
AbHeLlRaZoR
Canada's Ghost
AbHeLlRaZoR's Avatar
just keep pulling it'll pop on out.
Old 03-04-2009, 04:27 PM   #5
ryanJ
ryanJ's Avatar
ryanJ is on a distinguished road
Id seriously suggest using a panel removal tool on those clips. Ive broken several of those clips by just pulling with my hands
ryanJ is offline   Reply With Quote
Old 03-04-2009, 09:33 PM   #6
Valley olds
Valley olds's Avatar
I wasnt able to pull mine, so so what I did is I got a kind of thick wrench and squeezed it under that panel. After that there was a little gap through which I put in the wire a little at a time. I did this going front to back for the middle panel.
Old 03-04-2009, 10:53 PM   #7
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
cool.
