Old 06-16-2004, 09:21 PM   #1
White_Alero
Ok i have brake problems and need help. First off i have a screeching that is pretty loud, it happens sometimes on and off. Second tonight after driving around for an hour i got home and felt my rotors to see if they were heating up and yes it burned me. (not bad though) I got rotors and pads on the front at the dealer when i got my car. Does anyone know what it could be?
Old 06-16-2004, 09:25 PM   #2
brsexton
I have no idea what the noise would be, but its VERY normal for the rotors to get very hot. Rotors will burn a bad blister after driving if you touch them. The noise may just be some dirt or something traped between the rotor and pad.
2005 Honda CR-V AWD
Old 06-16-2004, 09:33 PM   #3
White_Alero
It seems like a metal on metal screech but sorta sounds like when u get your brakes wet but even when there dry it does it?
Old 06-16-2004, 09:48 PM   #4
brsexton
How many miles and how long has it been since the brakes were replaced?
2005 Honda CR-V AWD
Old 06-16-2004, 09:57 PM   #5
freeze12
Make sure the brake fluid level in the master cylinder is not all the way up as if it is the fluid heats up..expands & applys the brakes.I have seen a lot of people overfill the master cylinder!
...Dan...
Old 06-17-2004, 09:28 PM   #6
White_Alero
what could be causing the awfull sounds?
Old 06-18-2004, 07:56 AM   #7
brsexton
Your brakes may be shot and need to be replaced. How many miles do you have on them?? Also the OEM brake pads for the Alero don't last long AT ALL. My car needed new pads and rotors at 16k. Although that is all city driving, they still should have lasted longer.
2005 Honda CR-V AWD
