03-11-2009, 03:13 PM
big 3,
03-11-2009, 03:40 PM
03-11-2009, 03:42 PM
You need to use two 13mm wrenches, one on each bolt. Can't really do anything about the wire twisting with the bolt, just have to find a way to get it to work.
03-11-2009, 03:56 PM
03-11-2009, 03:59 PM
If you can get a pair of pliers SAFELY onto the bolt closest to the alt then it should do the same thing, or two pairs of pliers... Improvise man just don't break anything.
03-11-2009, 04:03 PM
03-11-2009, 04:07 PM
that is the most important line in the upgrade lol without it you just upgraded the grounds on your car but not the power
03-11-2009, 05:03 PM
03-11-2009, 05:36 PM
When I did this it was so cramped and close in there I didn't even attempt to take the bolt right out. Instead I clipped off the end of my ring terminal, and made it a spade. Loosen the bolt, slip it in and tighten.
03-11-2009, 06:53 PM
Try putting a 1/2" Open end wrench on the alternator side and a 13mm socket on the nut.
13mm= .511", .5" = 12.7mm- and wrenches are always a bit over. Should work
03-11-2009, 09:12 PM
03-11-2009, 10:06 PM
Originally Posted by itsbmw
I am not leaving aleromod tho.
damn.
we were so close
03-11-2009, 10:08 PM
damn.
we were so close
eff you
03-20-2009, 12:44 AM
Sorry to thread Jack. But since you are no longer an alero owner I think it is fair game
Is the alternator fused? Or is the new wire directly connected from battery + to alt?
03-20-2009, 12:51 AM
no its directly from the batt to the alt.
and also thread jack, does this upgrade really make that big of a difference? cause i have a serious power need problem with my system
03-20-2009, 07:20 AM
its directly connected. when you upgrade, you CAN put a fuse inline, but you don't need to.
yes, it makes a huge difference.
03-20-2009, 10:06 AM
Considering the stock wiring is equiv of 10 ga. hell yes its a huge upgrade, noticeable AND measurable.
03-22-2009, 10:21 PM
The Aleromod PITA
what it the big 3 other then gm ford and chrystler
03-22-2009, 10:33 PM
I know for a fact you've read and posted in threads about this upgrade. Were you dropped on your head or something? Do a search already.
03-22-2009, 11:04 PM
The Aleromod PITA
heads amps and subs is what ive posted about i think is that it
was wondering what the Big 3 was becasue of the title of this forum, reading it it didnt seem to realate to 3 anything
