Old 06-21-2004, 10:49 AM   #1
ptrudel
Designated Drunk
first of all, disconnect negative terminal from battery(u will be working with the airbags)
then, start by the trims around the shifter and radio, remove radio, remove steering wheel(pic below)to do this, remove the 2 torx screws holding the airbag in place and pull off slowly, there are 3 wires there, a red, a black and a yellow...disconnect all of 'em.
then, loosen the fat nut in the middle of the steering wheel, and use the puller to take steering wheel off.NOTE: there is alot of pulling required to get it off, don't be scared to pull
then, remove gauges, disconnect ignition and 4way flashers and dimmer switches.
remove the piller arms(ones that run along windshield)
remove vent(windshield defroster)
remove center console if u haven't done this yet(arm rest one)
remove screws holding in the dash and remove
it'd be a good idea to have another set of hands handy when u remove the dash, even more important when u put it back in, don't want to scratch the new paint
hope these instructions help :thumbsup:
I'm baaaackk
Old 06-22-2004, 06:28 PM   #2
alerocity
thanks for the how to
Old 06-23-2004, 08:18 AM   #3
ptrudel
Designated Drunk
no prob :thumbsup:
I'm baaaackk
Old 06-23-2004, 09:09 PM   #4
polarexpress17
polarexpress17 is an unknown quantity at this point
Send a message via AIM to polarexpress17 Send a message via MSN to polarexpress17 Send a message via Yahoo to polarexpress17
by that you mean "A-Pillars, even tho the way u said it makes people understand it better
polarexpress17 is offline   Reply With Quote
Old 07-05-2004, 07:21 PM   #5
slikrb
how do u get the steering wheel off? what size torques r they?
Old 07-06-2004, 08:00 AM   #6
ptrudel
Designated Drunk
i think they were T-25's....not 100% on that tho...they're a pain to get at
I'm baaaackk
Old 08-17-2004, 10:39 AM   #7
DJSpyboy
Just starting to get the parts off. Is the area asround the glove box seperate or does it just look that way?
Old 08-17-2004, 12:44 PM   #8
havik
^ The glove box itself can be removed from the dash, so it is separate
Old 08-02-2005, 02:31 PM   #9
Eh_nigma
the "Why Not?" Guy
Eh_nigma's Avatar
Eh_nigma is an unknown quantity at this point
Send a message via MSN to Eh_nigma
How in the world does one take the rubber cover off the center of the wheel? I've taken off the two screws on both sides, and yet... nothing... any help appreciated
-Everything
"Why an Alero?"
-Why the hell not?
Eh_nigma is offline   Reply With Quote
Old 08-03-2005, 08:20 AM   #10
ptrudel
Designated Drunk
the airbag you mean?
I'm baaaackk
Old 08-05-2005, 05:34 PM   #11
Eh_nigma
the "Why Not?" Guy
Eh_nigma's Avatar
it's taken care of... there was "gunk" holding the a.b. assembly to the wheel... nothing a little WD-40 couldn't fix...
-Everything
"Why an Alero?"
-Why the hell not?
