04-06-2009, 12:14 PM
The Aleromod PITA
fog lights and ebrake
Yeah, what is involved with wireing a set of stock headlights in to an Alero that didn't have them from before.
Wire running: Are the wires already there? What is the situation with the fuses on teh passenger side?, And mounting them? Or anything I haven't mentioned.
Is there a how too on this?
And, is there anyopions for making the ebrake handle different?
04-06-2009, 12:49 PM
Wiring for the fog lights should already be in place, its part of the wiring harness
The E brake just sucks, you could make it suck more or suck less but it would still just suck
04-06-2009, 12:52 PM
We are going to have to make a thread to decipher what you say sometimes...LOL
04-06-2009, 03:41 PM
you can connect it to your low beam lights and ground it on a bolt!
04-06-2009, 05:16 PM
Lol, this guy got into college but cant make complete sentences on a forum. Grr. I hate reading any of his threads. By the time I decipher the question, my brain hurts and I cant help out with the topic at hand
04-06-2009, 05:36 PM
agreed. all the posts i see from him look like he wrote the sentence out in another language and then put it into a free online translator and then posted them on here. plus the avatar of his goofy face just gets to me every time. :\
04-06-2009, 05:38 PM
very true.....
04-06-2009, 05:48 PM
x2.....
04-06-2009, 06:11 PM
ROFL at every responce^^^.
Anywayz, not every car has the wiring already there. Both of my Alero didnt have it, they are Gx btw.
04-07-2009, 02:24 AM
Yep, my Alero doesn't have wiring for the fog lights either. I did however pick up a '01? front lighting harness to swap in. It'll add the plugs for the fog lights and also switch my DRLs to the high beams.
After that, if you want it to be just like stock, you'd have to wire in the wires from the relay to the BCM and the switch to the BCM. As well as get the fog lights enabled.
04-07-2009, 04:15 AM
i think i'll just get the stock housings... and the stock switch on the vent... and run a relay and my own wiring... seems easiest
04-07-2009, 08:34 AM
HERE IS THE TRANSLATION
What is involved in wiring up a set of stock foglights to an alero that did not have them before, are the wires all there? are the fuses there and the connection points that follow and can be soldered on? are the mounting locations there along with a HOW TO?
Also, are there any options for making the Ebrake handle look different?
04-07-2009, 12:06 PM
The Aleromod PITA
lol hola yo soy Aleroracing lol
I will fix it, yesh! I hate punctuating.
04-07-2009, 05:18 PM
Leave the kid alone!! I think he's OK
The Ebrake sucks, but I'm pretty sure it doesn't come off. Mine doesn't
04-08-2009, 12:01 AM
The Aleromod PITA
I saw a piece at Autozone for 7 dollars, looked like it attached to the top of the ebrake. Looked like a pos, was wondering if there was anything like that, that was worth anything?
04-15-2009, 11:21 PM
The Aleromod PITA
bump.
04-15-2009, 11:57 PM
the part you saw was prob an aftermarket shifter knob, not a e-brake knob. i don't even know if they make those...
as for the fogs, i'd just run dedicated power and relays for them, and then just hook them into a small switch on the inside so on is on and off is off whenever you want.
04-16-2009, 12:33 AM
The Aleromod PITA
no it said ebrake cover it was by the shift knobs, supposed to look carbon fiber
