Go Back   Aleromod.com > General Help > Product Reviews
Old 04-19-2009, 09:45 PM   #1
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
B&M Shift Kit
sorry AbheLLraZor i tried searching, got mixed results and just confused
if asking for any member using this product on an automatic ecotec to post your results and opinions
and what does this mean the B&M tricks the computer, it isnt one of those nightmare resistor products is it?
Im concerned about what harder shifts means and does this help or hurt gas mileage
Old 04-19-2009, 09:50 PM   #2
AbHeLlRaZoR
Canada's Ghost
AbHeLlRaZoR's Avatar
well can't say I didn't try.
Old 04-19-2009, 09:53 PM   #3
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
you did and i appreciate it i read that and the forums i found, alotta questions on install, but no reviews afterwords
Old 04-20-2009, 02:03 PM   #4
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
bump. yall have them, just lemme know aobut em
Old 04-20-2009, 04:31 PM   #5
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
if you don't go to the racetrack with your car, don't even bother. These are a performance mod which helps knock off anywhere from .001 to .100 off a quarter-mile drag time on an automatic transmission.
Old 04-20-2009, 09:29 PM   #6
knuckleballer32
knuckleballer32 is on a distinguished road
i have one. install was ok. i highly recommend soldering it in if you get it. the result were fun i guess but like albino said its good for racing and knocking maybe a hundredth of a sec of. do it if you wanna feel a stronger shift. I am also pretty sure it would be good if your tranny ever starts to slip.
knuckleballer32 is offline   Reply With Quote
Old 04-20-2009, 10:59 PM   #7
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
for the price id like to try it, it wouldnt hurt my mileage would it?
and by stronger shift you mean better no physically harder right?
Old 04-20-2009, 11:24 PM   #8
No it won't hurt your mileage, it just ups the shift pressures in the tranny. And yes, by that i mean a physically firmer shirt, like chrip tires into 2nd firm on the higher settings.
but for a dd, thats all its gonna be its a firmer feel. you won't see any gain unless you consistantly like to race up to speed on on ramp and at lights. it doesn't mess with the ecu at all so there is no pwer gain.
Old 04-21-2009, 12:32 AM   #9
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
ok this thing is a resistor set up though right, it makes perform better right, it does fool the motor into thinking it needs to work harder and keep it constant
Old 04-21-2009, 01:22 AM   #10
no it doesn't fool the motor one tiny little bit. it just makes your tranny shift faster and firmer, that has absolutely no effect on the engine. it doesn't make it work harder cause it only affects the SHIFT pressures in the tranny computer. thats all. your motor doesn't even notice anything. the only thing it makes better "performance" wise (if you could call it that) if quiker gear changes, hence the slightly faster drag times.
if you are taking it to the strip a lot, yea great thing to have. if you are building more power, also nice to have. for just an air lintake in a daily driver, you will be disappointed you spent the money just to get a harsh jerk b/t gears.
btw,the above sounds kinda like i'm yelling, but i'm not. its just how i explain stuff when i'm tired.
Old 04-21-2009, 12:33 PM   #11
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
ok so i doint want this for daily driving, but i do horse off to strips, havent race the alero yet though its stock, cept for the intake, so it is possible to wire this in with a switch, like those venom power chips
Old 04-21-2009, 01:16 PM   #12
wish you could use it with a tuned PCM, i'd be all over the one FS in the other thread.
Old 04-21-2009, 01:56 PM   #13
AlbinoMonkeyRat
Let's Play Army!
there is a switch on it, so it's not turned on all the time, but I wouldn't suggest getting it unless you race often. (off-stage 1-stage 2)
Old 04-21-2009, 02:58 PM   #14
coolgrinder33
coolgrinder33's Avatar
coolgrinder33 is on a distinguished road
deffinatly helps performance.Gas millage im going to guess not so much.Honestly there really are not that many gas millage mods that will really make a difference. There is a couple, but you driving style will help the most
coolgrinder33 is offline   Reply With Quote
Old 04-21-2009, 09:34 PM   #15
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i know theres no magic part to increase gas mileage, but somthing that adds a little or doesnt affect it, makes it more appealing to me, and im able to justify spending the money in my mind easier
plus itd be amazing if i ended up with an alero that averaged 37 or so highway, with out being gutted and chopped up to remove weight
Old 04-21-2009, 09:48 PM   #16
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
I'm using it on an automatic w/ ecotec. I recommend, but if you drive like a granny (lol mileage?) don't bother. Much faster shifting, and keeps your RPMs up so if you're hard on the throttle you don't get jerked forward during a gear shift due to negative G force. If you're worried about how much you spend on gas don't get it, because it pushes back the shift point, to a higher RPM, which means more gas burned.
PS. You know mileage and the name AleroRacing don't really jive.
Misuseofyou is offline   Reply With Quote
Old 04-21-2009, 10:12 PM   #17
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
so?, your mad caouse its not your name lol
i dunno i like the car to perform when i run it hard
i like to conserve when im just driving to work, living here its a 20-30 minute drive to anywhere, racing is pointless in a 55
when i first got my liscense i raced everywhere mad alotta troopers mad, they breathed down my neck everychance they got, only pinned ticket was a following too close though, but that was teh gayest possible he coulda wrote, points wise
Old 04-21-2009, 10:24 PM   #18
Misuseofyou
I'm mad that you haven't had an up close and personal meeting with a telephone pole.
Old 04-21-2009, 10:26 PM   #19
37mpg alero? ha i laugh at you.
Old 04-21-2009, 10:53 PM   #20
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
truck met a ditch once, drove out unharmed with the aid of a tow truck, it wasnt a 4x4
