Old 04-22-2009, 09:51 AM   #1
OK to use regular Antifreeze / Coolant?
Doing the manifold soon.
What to know if it's OK to flush out all that Dexcool crap and run regular, good ol' American, killing the deer that drink the stuff leaking out of the car, green coolant
Old 04-22-2009, 09:56 AM   #2
jackal2000
jackal2000's Avatar
just use the all make/model stuff. you can't go wrong.
Old 04-22-2009, 10:05 AM   #3
CactusWill
Use whatever you want, just don't mix em.
Old 04-22-2009, 10:54 AM   #4
i used all makes/models.... seems fine for me
Old 04-22-2009, 11:11 AM   #5
Yea, I'm using the green stuff, My engine is running cooler actually.
Old 04-22-2009, 12:25 PM   #6
guiguilandry
guiguilandry's Avatar
yeah no problem to run on the green one, I run on it on all my car... I always flush the dex-cool because it is too acid for the engine.... but remember to do a full flush to get rid of all the mud the dex-cool leaves into the rad and water jacket in the engine....
Custom or Nothing...
www.demonautosport.ca
Old 04-22-2009, 12:33 PM   #7
I only run the green stuff.
Old 04-22-2009, 12:40 PM   #8
i know, im still flushing out the mud in the engine, three flushes later and still muddy
Old 04-22-2009, 01:28 PM   #9
I always run Dex-Cool with no issues yet..
But either way, you can do it. However you just have to change your coolant sooner.
You might also consider G05 coolant. Many other manufacturers use it, it's not as acidic as dex-cool but doesn't have all the silicate of the green stuff.
Old 04-22-2009, 07:09 PM   #10
I know about the green stuff and what it leaves behind.
OK I will be doing the switch, along with a new Stainless Steel Upper raditor hose
Old 05-19-2009, 12:01 PM   #11
zzyzzx
zzyzzx's Avatar
After doing a bunch of reading, I'm pretty much convinced that I should flush out the Dex-Cool and start using the regular stuff. I assume that is what everyone here does eventually?
Old 05-19-2009, 12:11 PM   #12
CactusWill
I haven't had any problems with it YET, it seems to be only certain dex cool that causes the problems. My dads impala blew up from the limg and dexcool, my moms saturn is caked with dex cool, but when I look in the coolant reservoir of the alero its clean as a whistle while being full of dex cool. Only do the swap if you see the sludge.
Old 05-19-2009, 10:20 PM   #13
whiterider00
whiterider00's Avatar
same here. i have over 170k on my engine, and its got dexcool in it, and it looks brand new. no idea when it was last changed, but there doesnt seem to be anything building up, so if it isnt broken, dont fix it.
Old 05-19-2009, 10:56 PM   #14
LIMG gasket change in less than 40,000 miles, I'd call that broken
Old 05-19-2009, 11:38 PM   #15
yea most people including myself wait for when they are doing the gasket swap and just drain/flush the system and put the new coolant in with the new gaskets.
Old 05-20-2009, 08:12 AM   #16
zzyzzx
zzyzzx's Avatar
My internet research seems to be indicating that I should switch to regular anti-freeze at some point so, I will. Yes, I probably will wait until I'm doing something else to the car. Someone here said they know of a failure at 8,000 miles, but I have also found people complaining about it at 167,000 miles too (and I have to wonder about that person). If Dex-Cool is so bad, how come it's only a problem on the V6 Alero's? I would think it would be just as bad for the 4 cylinder models as well.
Old 05-20-2009, 08:52 AM   #17
you do know, that all coolants eat the orig. gaskets..... they will go no matter what
Old 05-20-2009, 08:58 AM   #18
surreal_awakening
surreal_awakening's Avatar
The problem on the V6 is not the Dex-Cool, it's the gaskets that were used. But for the record, i switched away from the Dex-Cool a long time ago. I'm using the yellow "mix with any type" stuff right now.
Old 05-20-2009, 09:01 AM   #19
yellow?? lol im waiting for the rainbow antifreeze
Old 05-20-2009, 10:17 AM   #20
yellow is the ford standard. pretty sure its generic stuff. (both of my parents cars came w/ that)
I'm pretty sure when nate said 8k.. he meant 80k. i've never heard of anyone having a dead gasket at 8k miles.
