Old 04-23-2009, 03:26 AM   #1
irondiezl3
irondiezl3's Avatar
if it does this when its wet out
ok i did a search on yahoo and google. heres what ive gathered. my car since the day i bought it two years ago hesitates almost to the point of stalling when it rains or snows. if you hit the gas decent pressure you can overcome the hesitation but obviousley sumthins wrong. it hasnt got worse still the same its driving me nuts. its only when its wet out. i dont have a cold air intake i thought it was that changed it still have problem thought it was fuel issue changed filter used water remover which actually seemed to help. online my search pulled up this answer almost everytime, moisture in coil packs or wires connected to it. so anyone ever have this issue or have an idea here? i am not taking it to a mechanic to rape me on hours on end for diagnosis.
Old 04-23-2009, 09:31 AM   #2
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
thats what she said. and i really dont know, to be honest. so this ONLY happens when it rains outside?
Bad99Olds is offline   Reply With Quote
Old 04-23-2009, 12:45 PM   #3
irondiezl3
irondiezl3's Avatar
yes and the more it rains the worse it is to its very wierd i had a car when i was a teenager that did this but i had a huge whole in my exaust where water was getting in exhaust is solid on this one. very very wierd
Old 04-23-2009, 10:05 PM   #4
Could water be running down into the fender?
Old 04-23-2009, 10:23 PM   #5
he got rid of the CAI
Old 04-24-2009, 02:51 AM   #6
sounds like your intake tubing could be messed up, or your past intake ruined one of your sensor such as your MAF
Old 04-25-2009, 11:38 PM   #7
irondiezl3
irondiezl3's Avatar
i guess ill have to wait until it throws a code.
Old 04-25-2009, 11:44 PM   #8
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
did you recently get exhaust work done? I'm thinking perhaps an exhaust leak, and humidity might get in between the header and cat and temporarily clogging the system. but yeah, get the code.
Old 04-25-2009, 11:52 PM   #9
irondiezl3
irondiezl3's Avatar
i looked and didnt see any holes im pretty sure exhaust is good but maybe its in a not so visible spot it is stock exhaust.
Old 05-20-2009, 05:40 AM   #10
FamousFresh
FamousFresh is on a distinguished road
yea i have the same problem sometime but it doesnt happen when it rains its more random than anything i can be driving and everything is ok then i come to a stop and it starts to hesitate and if i dont keep my foot on the gas it will cut off but starts right back up havnt figured out what it is but now that i thing about it when was the last time you had a tune up try spraying the wires with a silcone spray and see if that stops it if so your wire was bad if not i dont know what it is but if you figuer it out let me know cause its makin me mad as hell
FamousFresh is offline   Reply With Quote
Old 06-07-2009, 08:13 PM   #11
arsenal
arsenal is on a distinguished road
clogged cat?
...my 3400 would studder alot when the humidity was high. we cut the cat off, hollowed it out and put it back on and it ran much better solving the problem but in turn creating the need for a new cat. stinks way too much. prolly get a magnaflo high flow.
arsenal is offline   Reply With Quote
