Old 04-23-2009, 04:20 PM   #1
robrage2006
robrage2006's Avatar
robrage2006 is on a distinguished road
Snow tires
Hello all,
Will snow tires off a 93 grand am fit on the Alero
robrage2006 is offline   Reply With Quote
Old 04-23-2009, 04:38 PM   #2
CactusWill
Depends on what the rim size is, grand ams came with several different rim sizes.
Old 04-23-2009, 05:06 PM   #3
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
my ex had a 94 Grand Am. I can tell you, that since the 93 and 94 are essentially the same car that the 93's wheels will most likely NOT fit the Alero. (odd, they will fit the 2002 J-body)
Old 04-23-2009, 05:57 PM   #4
robrage2006
Thanks for your input i'll check the size and bolt pattern to see
Old 04-23-2009, 07:45 PM   #5
Bolt pattern shouldn't match, but the tire itself might if your rims are the same size.
Old 04-23-2009, 10:42 PM   #6
AlbinoMonkeyRat
Let's Play Army!
not without recalibrating the speedometer. those tires will have a smaller overall diameter.
Old 04-24-2009, 12:40 AM   #7
Actually, the older N-Body used a very close overall diameter tire to the Alero. The tires are out if they're 14" though. The wheels are also out if they're only that one bolt pattern. Those older N-Bodies are 5x100 where the Alero is 5x115.
