Old 04-23-2009, 10:13 PM   #1
Meet Everlast.... and all her problems...
here is the good video's and me being bored
http://www.youtube.com/watch?v=U59eG...eature=channel
http://www.youtube.com/watch?v=xYHgW...e=channel_page
aaaaaand the problems........
http://www.youtube.com/watch?v=_2MzL...eature=channel
Old 04-24-2009, 11:31 PM   #2
Old 04-25-2009, 01:29 AM   #3
Atmosphere
Atmosphere's Avatar
Atmosphere is on a distinguished road
Looks good. Total cost?
2K 3.4L 4DR GLS
Atmosphere is offline   Reply With Quote
Old 04-25-2009, 04:56 AM   #4
GA_turbo
GA_turbo's Avatar
GA_turbo is on a distinguished road
ok this is what you need to fix
1 trunk- open the trunk and see if the safety lock is on or it just needs to be lube it up.
2 fogs- get a new relay for them or just clean the connectors on the relay, sometimes its just a bad connection on the relay, my grand am did the samething.
3 noise from sterring wheel- it could be the inner or the outter tie rods, most likely the outers, its not going to be the strut mount, the strut mount when it goes bad you can only hear it when you turn the wheel almost completly, it would either make a loud clunking noise or just a grinding noise.
To check the tie rods lift the car up and move the tires by hand left and right and the one with the most play need to be replace, highly recomend doing both at the same time if you are going to replace them.
4 cruse switch- get new one from the salvage yard.
GA_turbo is offline   Reply With Quote
Old 04-25-2009, 08:46 AM   #5
total cost?
Car - 300$ (back of dealer lot, nothing but LIMG was broken)
LIM Gaskets - 100$
Other Assorted Gaskets - 45$
Uhhhh, Other Assorted Body and Paint Items, - 45$
so? thats it to obtain and get a running alero
needs, so far before its inspection,
2 Hubs.... 2 outer tie rods, uuuh, thats it to pass inspection..
what it needs just to be fixed,
fog relay, trunk button, new aftermarket fans, sand bondo and paint it, fix hood chipping,......j
