Old 05-03-2009, 09:37 PM   #1
daiglepatrick
daiglepatrick is an unknown quantity at this point
Engine loss of Power???
ok..my Alero is driving realy weird lately. the problem that I'm having usually happens when I'm driving at higher speed or I'm driving at a consant speed and try to accellerate. Today I was driving on the highway and I had a hard time going faster than 100km/h...the car was fine when I was driving around 90....I started to accelerate and as the car shifted the engine kind of loss power...at first I tought the transmission was slipping but the rpm didn't shoot up it stayed more or less the same...the motor just loss power and the engine is not running right. I let off the gas and it runs ok. it seems to be worse going up hills or when the engin is working harder.
a bit of history on my 2000 Alero
3.4 v6
295000km
I recently changed all the plugs and I just checked them yesterday and they look fine
changed fuel filter last week
I have a small leak in the front exhaust manafold gasket...don't think that would cause the problem
I also had the transmission fluid level checked out and it was fine
Anyways any help would be appreciated....I have no clue what the problem could be....engine dying, bad sensor, transmission....not sure
I'm planning to bring it in at the dealer to get checked in a couple of days but would like to fix it before then.
daiglepatrick is offline   Reply With Quote
Old 05-03-2009, 10:08 PM   #2
guiguilandry
guiguilandry's Avatar
clogged cat....
Custom or Nothing...
www.demonautosport.ca
Old 05-03-2009, 10:10 PM   #3
unhook the battery for the night, and then hook back up tommrow, it will shift like it's on crack for a while, b w/ea
Originally Posted by guiguilandry View Post
clogged cat....
try my thing first, then that,
Old 05-03-2009, 10:10 PM   #4
^eff that, disconnecting the battery does NOTHING to help a problem.
Clogged cat..
Old 05-03-2009, 10:11 PM   #5
Clogged cat..
helped me....
Old 05-03-2009, 10:12 PM   #6
And why is that? The car doesn't learn anything but minor fuel adjustments. Nothing should happen to drastically alter one of those that by resetting it to have to relearn the fuel trims would fix it.
Old 05-03-2009, 10:13 PM   #7
huh, as far as i knew, the car also learns your driving habits, this same thing happened to me, and i did that, and it fixed it
Old 05-03-2009, 10:15 PM   #8
No it doesn't "learn" your "driving habits", what the hell? The transmission has a SET tune. It shifts when and how quickly it is supposed to.
When my battery is disconnected for any period of time, day, week, etc. Nothing changes... I lose my radio settings... that's it.
Old 05-03-2009, 10:16 PM   #9
huh, as far as i knew, i thought the car "learned" your driving habits and, made changes to shifting, etc accordingly
