05-05-2009, 11:11 AM
Interior Mod
Hey Whiterider00
I m looking into doing something like your interior ( Black with the plastics painted White ) And i m wondering how you did all that and if it was expensive.
Did you need a special paint for the plastics and how did you get the rest black?? ( paint???)
Take Life's Curves Sideways, and Drift!
05-05-2009, 11:29 AM
Let's Play Army!
plastic parts: use Krylon Fusion
vinyl parts: use vinyl dye (you get what you pay for with this, too)
Originally Posted by black
05-05-2009, 12:21 PM
kool its as easy as that????
05-05-2009, 03:29 PM
lightly sand first.
05-05-2009, 04:13 PM
Let's Play Army!
^ true, prep is the hardest part. Sanding and washing.
05-06-2009, 06:38 PM
is black vinyl expensive and is the difference of color originally gonna make a difference after dying???
05-23-2009, 04:54 AM
Sorry to bring this back, I know I saw it somewhere but now I can't find it.
I've painted over all the pastic in the interior, and I really want to do something to all the Vinyl, ( must be black!).
I know everybody regrets painting their vinyl, but even in a couple of years if it chips, can't it be cleaned up and repainted? One weekend and 50$ should clean it up again.
I don't know ANYTHING about fiberglassing, and I don't really like it.
Re-doing the vinyl would be an option, has anyone tried that?
Or what about the vinyl dye? Does anyone on here have it, and it still looks decent? If so, what was your application procedure?
04 Black 2dr, 5spd, Custom Black and White Interior, Custom Stereo Mount with Ipod dock in dash, Dual Gauge pod; A/F & Volt, White Face Gauges.
05-23-2009, 12:51 PM
I dyed my vinyl all white with vinyl dye at auto zone. Its like $7 a can. You will probably need two cans. I needed more because white doesnt cover the darker vinyl very well, but I would imagine black would work the best.
For prep. work, I cleaned everything real good with alcohol. It came out just fine.
05-23-2009, 01:03 PM
The Aleromod PITA
hey im wondering, does the vynil spray die work on the steering wheel aswell?
and how long do i need to set aside for this project, drying time/prep
05-23-2009, 06:54 PM
The steering wheel is leather, so I dont think vynil dye will work on it very well.
05-24-2009, 03:51 AM
Hey Bizarre, did that work with the carpet as well?
05-24-2009, 07:22 AM
For the carpet go to http://www.stockinteriors.com/ thats were i got mine from its molded and you just have to cut out the slots for the seats and center shifter
05-24-2009, 11:47 PM
Sweet, I'll check that out!
05-25-2009, 01:43 AM
The Aleromod PITA
if theres a good solution for the roof, seats, and steering wheel id redo my interior like next week
05-25-2009, 03:40 PM
Easy wrap the headliner in what ever you want and buy new seats and steering wheel
05-26-2009, 01:41 AM
I need to figure out how to get the dash apart, I'm going to either dye it this week, ( if that fails then it's time for re-upholstery )
But I'll need to know how to get the steering wheel and passenger airbags out without detonation....
05-26-2009, 08:09 AM
disconnect the battery, and they can't.
05-26-2009, 12:06 PM
Its Beer Thirty
I would disconnect the battery and the yellow airbag wires in the fuse panel in the sides of the dash.
Originally Posted by Daytona
05-26-2009, 12:16 PM
if you disconnect the battery, there is no reason to disconnect anything else. no power means no power.
can't activate w/o the switch energized.
05-26-2009, 01:08 PM
MAKE SURE that you wait at least 5 min after disconnecting the battery to take the airbag out. there is a feature that keeps voltage going to them so if you get into an accident and your battery gets disconnected, the airbags will still work. so wait before pulling it out or you will have an airbag in the face, and be out about $500-600
