Old 05-08-2009, 10:52 AM   #1
Th0r
Th0r's Avatar
Th0r will become famous soon enough
Wheel spacers... *digs fox hole*
I'm not particularly fond of how the rear wheels are tucked into the body more than the fronts, so I'd like to push them out a bit. My wheels aren't available in a different offset and I'm not wanting to buy 4 new wheels.
I know wheel spacers are death for a car so I'm not even looking into those. How about the wheel adapters? They look pretty solid, but I don't want to use anything that could hurt the vehicle. I haven't found any reviews other then positive marketing. Opinions?
GX Coupe
Dropped and Blown
Th0r is offline   Reply With Quote
Old 05-08-2009, 10:58 AM   #2
jackal2000
jackal2000's Avatar
whats wrong with spacers?
Old 05-08-2009, 11:06 AM   #3
doesn't oldsman have tires that stick out in the back?
how did he do his?
Old 05-08-2009, 11:14 AM   #4
Oldsman
Owner
Oldsman's Avatar
i used wheel adapter which also space out. they are 1" and have not had any issues.
if you do spacers you should also get long wheel studs.
Beware of the BackStabber
Old 05-08-2009, 11:22 AM   #5
rowdygls
rowdygls is an unknown quantity at this point
Send a message via AIM to rowdygls Send a message via MSN to rowdygls Send a message via Yahoo to rowdygls
I'm using spacers in the rear but I don't have longer wheel studs. My spacer is 1/4" at most though, which is all i needed.
my cardomain: http://www.cardomain.com/ride/605233Alero
Chapter Member
rowdygls is offline   Reply With Quote
Old 05-08-2009, 11:24 AM   #6
Oldsman
Owner
Oldsman's Avatar
now your wheel lugs have 1/4" less thread in them than factory. Which works but not as safe. I would replace with longer studs just for a safety factor.
Old 05-08-2009, 11:36 AM   #7
as long as you aren't putting alot of lateral stress on them, you'll be ok. Only thing that might prove a hindrance to spacing the wheels out more is if you go to lowering later on, where you won't have the wheel-well clearance.
Old 05-08-2009, 11:40 AM   #8
SittinOnChrome
SittinOnChrome's Avatar
SittinOnChrome is on a distinguished road
Send a message via AIM to SittinOnChrome Send a message via Yahoo to SittinOnChrome
I Always Wondered Why Oldsmans Wheels Were Sticking Out Like That..... Now I Know Nice Mod I Like The Look...
SittinOnChrome is offline   Reply With Quote
Old 05-08-2009, 11:47 AM   #9
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
the spacer is gonna be your best bet. you dont need them to come out much at all, 1/4" would be more than enough.
an adpater will have to be much larger than you need thus pushing the wheel out too much and will look like garbage.
FrankTheTank is offline   Reply With Quote
Old 05-08-2009, 12:29 PM   #10
It will technically put more stress on the wheels bearing, since the extra distance gives the wheel more torque on them. However, from the sounds of it, it's not a problem to be worried about.
Old 05-08-2009, 12:36 PM   #11
Its a lever effect.
Providing you have at least 3/4" of each stud sticking out you should be fine. Thats about as much engagement as a stock lug nut provides.
If anyone wants to be technical, you should have 1 1/2" depth as you do diameter. Thats the shear stength of the bolt then.
Old 05-08-2009, 12:56 PM   #12
Oldsman
Owner
Oldsman's Avatar
this i know.........it sucks but with the huge OSV wheels and tires I have no choice.
Old 05-08-2009, 12:58 PM   #13
Oldsman
Owner
Oldsman's Avatar
yep i did the spacing to match the OSV. Because the OSV had a 1" spacer but like the OSV, I had to not only do it for the look but also clearance between the tires and the springs on the coilovers.
Old 05-08-2009, 12:59 PM   #14
Th0r
Th0r's Avatar
Are you running stock springs Oldsman? What size are those OSV wheels/tires cause it practically looks dropped.
I'm already dropped 2" up front and 2.5" (gah!) in the rear.
GX Coupe
Dropped and Blown
Old 05-08-2009, 01:08 PM   #15
Oldsman
Owner
Oldsman's Avatar
I am running custom adjustable koni coilovers that came off the OSV. the wheels are 18x7.5 with 255/40r18 pilot XGT. My car is dropped but not too much so the tires don't wheelwells.
Old 05-08-2009, 01:35 PM   #16
Th0r
Th0r's Avatar
Gotcha. Last question then I'll leave ya alone.
What spacer are you using on the rears? Is it just a 5x114.3 to 5x114.3 or did you find a 5x115?
GX Coupe
Dropped and Blown
Old 05-08-2009, 01:47 PM   #17
Oldsman
Owner
Oldsman's Avatar
it is a 5x115 to a 5x114.3 1" thick.
Old 05-08-2009, 03:54 PM   #18
I have spaces and haven't had a problem! My wheels don't stick out at all, and I got 20's on there....just an FYI
Old 05-08-2009, 04:28 PM   #19
Crazytaxi37
The Dark Lord
Crazytaxi37's Avatar
Crazytaxi37 is an unknown quantity at this point
Send a message via AIM to Crazytaxi37
I've had 1" spacers on the rears for around 4 yrs and have never had a problem. Oldsman, I believe they are 5X115 to 5x115.
Crazytaxi37 is offline   Reply With Quote
Old 05-08-2009, 04:33 PM   #20
Oldsman
Owner
Oldsman's Avatar
they are.....i thought they were 5x114.3 being that is what the wheels are. maybe not, anyways 4 years here to and several 30-40mph curves at 75+ and no issues
