Old 05-10-2009, 12:09 PM   #1
chaimv
chaimv is on a distinguished road
car wont start
Hi Guys
I tried startignmy car today and it would not start. It cranks fine and tries to start. runs for about 2 seconds and dies. I here the fuel pump running. alos allf uses seem to be fine. Also once this happened my door locks stopped working. the security light is not on as i have done teh bypas.
Any idea
chaimv is offline   Reply With Quote
Old 05-10-2009, 12:15 PM   #2
hmmmm
damn, try again
Old 05-10-2009, 12:58 PM   #3
injectors gummed? check your air filter?
Old 05-10-2009, 01:26 PM   #4
chaimv
Filter is clean. car was running fine yesterday. i will try and look at the injectors
Old 05-10-2009, 04:26 PM   #5
how much gas in teh tanx?
Old 05-10-2009, 04:48 PM   #6
chaimv
Angry
1/2 tank of gas. More info for you. If I try startingthe car with the gas pedal pressed about a third of the way down after 5/6 tries it starts and runs fine. once i shut it down same problem. also all my gauges stopped working. IN teh cluster when i turn on the ignition the warning lights come on
Old 05-10-2009, 05:09 PM   #7
fielder87
fielder87 is on a distinguished road
^^if ignition is ahead,but car is not running those lights will come on.best thing to do is get OBD-ll read...
fielder87 is offline   Reply With Quote
Old 05-10-2009, 05:13 PM   #8
chaimv
the lights only come on when i turn on the igniton then they go off as normal.
only problems are guages, dome, lamp, pwr locks, all stopped working and my car wont start normally. I have read on other post that this could be a BCM problem. Coudl a new BCM fix teh starting issue???
Old 05-10-2009, 05:15 PM   #9
fielder87
i would check the fuses,with a test light if you got one.or pull and check(sometimes cant tell tho).
Old 05-10-2009, 06:01 PM   #10
sounds like an ignition cylinder issue, also the BCM with the window leak
Old 05-10-2009, 06:06 PM   #11
lord2heart
lord2heart is on a distinguished road
Send a message via AIM to lord2heart Send a message via MSN to lord2heart Send a message via Yahoo to lord2heart
check fuel filter and lines
lord2heart is offline   Reply With Quote
