Old 05-20-2009, 07:09 PM   #1
Colllin
Colllin is on a distinguished road
Stock radio no sound
Today my radio was working fine and all of a sudden no sound came out of the speakers. The radio is still working and on but no sound. I do have the monsoon system with the amp in the trunk.
Colllin is offline   Reply With Quote
Old 05-20-2009, 07:44 PM   #2
2000aleroff
2000aleroff is on a distinguished road
could be a wire in the back of the head unit. or the stock radio could just have blown a fuse or died. i suggest checking the wires and if they arent it try putting an aftermarket stereo in to see if that works
2000aleroff is offline   Reply With Quote
Old 05-20-2009, 08:47 PM   #3
Colllin
i've checked the fuses in the box is there one in the headunit that goes to speakers. has this happened to anyone else
Old 05-21-2009, 08:21 AM   #4
Colllin
anyone
Old 05-21-2009, 09:03 AM   #5
Its a blown fuse somewhere or the monsoon amp took a dump.
Old 05-21-2009, 12:00 PM   #6
Colllin
if its the amp how do i fix it
Old 05-21-2009, 12:02 PM   #7
SittinOnChrome
SittinOnChrome's Avatar
SittinOnChrome is on a distinguished road
Send a message via AIM to SittinOnChrome Send a message via Yahoo to SittinOnChrome
My radio was doing the same thing when I had a water leaking near my fusebox. I replaced my winshield after everything dried up it was back to normal working order.
SittinOnChrome is offline   Reply With Quote
Old 05-21-2009, 12:11 PM   #8
CactusWill
Theres 3 fuseboxes, you've checked all of them?
Old 05-21-2009, 12:19 PM   #9
You dont.
I would check ALL fuses first. Pull each fuse one by one, every single one of them. Replace all bad fuses. Even under the hood.
Give it a try then.
You may have a loose wire, but its highly unlikely.
If the amp is dead, its dead. Time for a stock replacement (ass raping) or you get to redo and justify a new system in the car... Stll expensive, but far better results.
Old 05-21-2009, 05:18 PM   #10
Colllin
checked every fuse and they are all fine how do i know for sure if its the amp can i just go get another one even though they suck i just want to listen to the radio. Also my reception from the radio has been getting worse and worse could this cause a problem
Old 05-21-2009, 05:38 PM   #11
the antenna is ON the back window. there is a little power amp that sits inside the C pillar. sometimes the connections go bad. you'd have to tear out the molding in the back and take a look.
Old 05-22-2009, 09:41 AM   #12
zzyzzx
zzyzzx's Avatar
You find another one in the junkyard. I've seen them. I don't know how rare or eBayable they are (if I knew I might have taken it).
Old 05-22-2009, 10:57 AM   #13
Colllin
My door chime doesnt work either
Old 05-22-2009, 11:02 AM   #14
Thats because it goes through the radio.
Old 05-22-2009, 02:34 PM   #15
02AleroEco
02AleroEco is on a distinguished road
Send a message via AIM to 02AleroEco
that sucks dude, id just get a new system all together.
But hey, unless im wrong, even if the amp died wouldnt the speakers still work, or were they completely powered by the amp?
02AleroEco is offline   Reply With Quote
Old 05-22-2009, 03:14 PM   #16
Um amps power speakers.
So ya if the amps dead, no workie.
Old 05-23-2009, 01:00 AM   #17
You'd have to bypass the amp if it were bad.
Old 06-16-2009, 12:21 PM   #18
Colllin
how do u bypass the amp would putting in an aftermarket deck solve this
Old 06-16-2009, 12:29 PM   #19
You would have to either run new wires to all the speakers or jumper the wires at the amp connector in the back.
Old 06-16-2009, 12:33 PM   #20
Colllin
if its the amp who it just be easier to get another one.
