This is a common problem with both the alero's and ga's. The problem is in your injectors, if it was an egr solenoid it would trip the computer and set off a code (unless it is stuck only partially open but that rarely happens)
The thing with the injectors is that they will have to do a couple hit or miss diagnosis on them before they start replacing.
First they'll probably try a purge, if that doesn't fix the problem, they will put the car on the scanner that measures pulse width on the injectors. The balance test will determine the pressure drop between the injectors. GM notices that a drop greater then 3 or 4 psi, i forget which, between the leanest and richest injectors is substantial evidence of a bad injector, they will replace the one or some times two injectors that stand out against the 6.
In rare cases, you have an electrical problem between the connectors on your injectors that they call fretting where movement and vibration between the electrical connections creates some sort of debris between the male and female ports that acts as an insulator, but that nifty engine light won't set off untill there is a complete loss of electrical continuity, so diagnosis is difficult.
I've never seen this fretting problem myself or have seen any of the other techs do one but we were told by gm that if that was suspected, just to use dielectric grease i believe between the terminals.
So
0.8 for diagnosis of lean and rich injectors, usually
whatever your local garage charges for a purge
1.2 for an injector replacement + 0.3 for each additional injector
If you want the fretting checked, your looking at straight time labour
Purging isn't covered under warranty
diagnosis is only covered under 3 year 60,000km
injectors are covered under manufacturer and extended warranties
Hope this helps or makes you cry
Just keep dumping STP crap in it and use really good gas for a while. May work
