Old 05-25-2009, 12:50 PM   #1
02AleroEco
02AleroEco is on a distinguished road
Send a message via AIM to 02AleroEco
Service engine light
Ok,
so my Service engine light came on the other night.
I went to Autozone and they plugged in the scan tool.
The code that came up was : Evap Emissions, vacuum.
Now all my hoses were fine. part of the power steering line is wet, but not leaking. my break fluid is down.
Me and a friend who is going for auto mechanics, came to the conclusion of the Vacuum pump? and that this woulda explained why i have a squeeling at certain times, while driving like straight and what not, accelerating ect.
Does that sound Buyable? or has anyone else had this issue and know what it was.
I have until September before i go for my sticker again, but id like it fixed as soon as possible just for my own piece of mind.
02AleroEco is offline   Reply With Quote
Old 05-25-2009, 01:20 PM   #2
99alerogirl
Female.
99alerogirl's Avatar
99alerogirl will become famous soon enough
evap emissions, vacuum? was it an evap emissions code and they said it COULD be a vacuum leak? usually the evap emissions codes point to something like a loose or broken gas cap, but if not that then maybe a vacuum leak.
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
99alerogirl is offline   Reply With Quote
Old 05-25-2009, 02:19 PM   #3
what number code, P0440?
A code P0440 could mean one or more of the following has happened:
The gas cap is not installed or working properly
The purge solenoid has failed
The canister is plugged and not working properly
Old 05-27-2009, 12:32 AM   #4
02AleroEco
I think that was the code yes, it rings a bell. buuuttt hahaha funny thing, the light went out today.
Old 05-27-2009, 10:50 PM   #5
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
check you gas cap seal, it caused mine to do this and apparently is common
Old 05-27-2009, 10:51 PM   #6
it'll come and go mine did for months
Old 08-06-2010, 10:28 AM   #7
Amun Ra
Amun Ra is on a distinguished road
It may be your EVAP purge solenoid. The hose leading to mine was broken and set off my light. On the 2.4 its mounted on top of the A/C compressor. It's an easy fix.
Amun Ra is offline   Reply With Quote
Old 08-06-2010, 10:56 AM   #8
^Good suggestion, but it's over a year later.
Old 08-17-2010, 09:06 AM   #9
zzyzzx
zzyzzx's Avatar
You replaced just the seal, or did something else?
Old 08-20-2010, 03:11 PM   #10
Spilly
Spilly's Avatar
Spilly is an unknown quantity at this point
Haha mine threw the same code and come to find out that was exactly what's wrong with mine.
Spilly is offline   Reply With Quote
Old 10-05-2010, 09:59 PM   #11
Bigshot44
Bigshot44's Avatar
Bigshot44 is an unknown quantity at this point
first day i bought my car i went to fill up and left the cap at the station. light came on, i flipped. i remembered that on my sunfire that the light came on cause the guy at the station didnt put it on properly so i looked and realized i forgot to put on the cap. i went back and they pulled out a box of caps and just gave me the nicest one :P
2003 Olds Alero 2.2L Eco
Ttop191: who gives a damn what everyone else thinks, if you are proud of it thats all that matters, dont let others persuade you into thinking what you like is wrong.
Bigshot44 is offline   Reply With Quote
