Old 06-08-2009, 05:13 PM   #1
transmisson problems
my spedometer is not working and the rpms are really off and the transmisson is not shifting smoothly it is having problems shifting I have to go down to 1st gear and then it will shift properly. if anybody can help me that would be great.
Old 06-08-2009, 05:15 PM   #2
Sounds like a modual somewhere.
Any SVS lights?
Old 06-08-2009, 05:19 PM   #3
yes check engine light is on
Old 06-08-2009, 05:21 PM   #4
IAT, where are you located in NH? i might be able to come and help you
Old 06-08-2009, 05:24 PM   #5
that is the problem I am not in NH I am in kentucky I am working down here for the summer is there anybody that lives in kentucky that is on aleromod
Old 06-08-2009, 05:25 PM   #6
change your location?? or did you just drive there?
its a 3400?
check IAT, MAP, sensors
Old 06-08-2009, 05:36 PM   #7
I just drove here I will be back in NH in august. are u going to the show up in lansing MI
Old 06-08-2009, 05:38 PM   #8
I drove there but I am going to be back in NH in august
Old 06-08-2009, 05:42 PM   #9
yeah, im going to A.S.S, i can help you there,
check your IAT, MAP
Old 06-08-2009, 05:52 PM   #10
I do not know if the car is going to make it there the engine sounds great I was wondering if there is something wrong with the tranny
Old 06-08-2009, 06:18 PM   #11
the engine is not idling smoothly
Old 06-08-2009, 06:21 PM   #12
umm, get a video with the idle, and driving the car..
btw: use the edit button please...
Old 06-08-2009, 06:23 PM   #13
IAT is not going to cause the speedometer not to work.
Sounds like you have a significant electrical issue.
Old 06-08-2009, 06:26 PM   #14
dude.... really? his tranny is not shifting correctly....
EDIT, i guess this is a new problem... that was an edit
Old 06-08-2009, 06:35 PM   #15
i do not have a camera with me
Old 06-08-2009, 06:35 PM   #16
Significant vacuum leak somewhere, IAT, and/or vehicle speed sensor.
Old 06-08-2009, 06:40 PM   #17
I found plastic peices that cover the wires and lines under my car I just found them
Old 06-09-2009, 12:17 AM   #18
sh8dybizness
sh8dybizness is on a distinguished road
Have you done the obvious and check the trans fluid? Also if you could pull the code the check engine light is throwing it would help!
sh8dybizness is offline   Reply With Quote
Old 06-17-2009, 04:52 PM   #19
zzyzzx
zzyzzx's Avatar
I was also thinking of VSS. A way of doing s crude check on the VSS that (at least on my Escort) the cruise control uses the VSS signal, so if the VSS is bad, the cruise control doesn't work. Again, on my Escort, the transmission uses the signal generated by the VSS.
VSS = vehicle speed sensor.
I'm also wondering if you have more than one problem. How many miles are on the car?
Old 06-17-2009, 05:09 PM   #20
RisenequinoX
RisenequinoX's Avatar
RisenequinoX is on a distinguished road
Send a message via AIM to RisenequinoX Send a message via MSN to RisenequinoX
the cruise control on my alero didnt work because i had low brake fluid....
100,000 Mi 3/29/2011
RisenequinoX is offline   Reply With Quote
