Old 06-09-2009, 05:38 PM   #1
Testing MAF
How?
this p0171 is driving me nuts (and hurting my mpg) I tried to replace the upstream O2. Kicked back on immediately. I cleaned the MAF with carb cleaner, kicked on immediately.
I have another MAF here ready to replace it, but i want to know how to test it/them, before hand. I can quickly eliminate, if i need to swap them, if i know what to test w/ my voltmeter.
So... how?
along with that.... i was also told to check for vacuum leaks, and exhaust leaks.. How?
Old 06-09-2009, 06:55 PM   #2
You happen to have a narrowband air/fuel gauge?
Old 06-09-2009, 08:16 PM   #3
no. When i say, how do i test it, i mean.. what voltage should it show, when its functioning?
Old 06-09-2009, 08:24 PM   #4
guiguilandry
guiguilandry's Avatar
you should have a 5 volt and a ground but the signal works with a frequency... in hertz..... and I don't know how much hz = how much volts....
for vacuum leaks, you can try to spray brake cleaner on all the vacuum hoses and all around the intake, normally vacuum leaks makes a hissing sound clearly audible....
for the exhaust leaks let's just say that you would hear it too if there is one big enough to cause that code to set...
I hope that it'll help you a little....
Edited, I hope that you did not spary carb cleaner on your maf while the car was running... if so, there is chances that you burned off the elements into the MAF
Custom or Nothing...
www.demonautosport.ca
Old 06-09-2009, 08:29 PM   #5
I asked because tapping into the O2's wiring sometimes sets off this code. It always showed up randomly when I had mine hooked up.
Old 06-09-2009, 08:58 PM   #6
which wire do u tap into? my gauge rolls back and forth
Old 06-09-2009, 09:06 PM   #7
guiguilandry
heineck, you mean that the a/f ratio goes to lean... rich... lean... rich... That's normal that's how a narrowband sensor work... is switch between lean and rich instead of being a linear output like a wideband is.....
Old 06-09-2009, 09:09 PM   #8
How?
So... how?
I have tested a MAF sensor with an o-scope just to see if it was basically functional, but testing one to see how accurate it is would be difficult. Best is just to sub in the other unit. A vacuum leak would make your LTFT's consistently much higher than normal.
Old 06-10-2009, 01:17 AM   #9
ltft??
and so the only good way to test it, is to yank the old, put in a new, and clear the code? (see if it comes back?)
Old 06-10-2009, 02:47 AM   #10
dragon8807
dragon8807's Avatar
dragon8807 is on a distinguished road
Send a message via Yahoo to dragon8807
LTFT = Long Term Fuel Trim
try the other one out, clear the code and see if it comes back or not
99 alero - totalled
96 impreza 5spd awd - sold
dragon8807 is offline   Reply With Quote
Old 06-10-2009, 11:05 AM   #11
ok thanks i was trippin out cuz i knew i did it right, thanks and mybad for threadjackin cherry
Old 06-13-2009, 10:12 PM   #12
replaced my MAF, killed the code. let run for several minutes. Code didn't come back yet. I hope its dead forever.
