Old 06-27-2004, 11:33 PM   #1
99Olds
I just bought these gauges off ebay. So I came on here to get directions. I only found the ones for white face inlays not wiht the indeglo. I have directions that come with they say to put them right over old face but on here it says to take them off. And would it be smart to replace the cluster bulbs in the back. Anyone with halos could help me.
Old 06-27-2004, 11:44 PM   #2
mdodge
mdodge is an unknown quantity at this point
Send a message via MSN to mdodge
If they are indiglo..like speedhut...they just install overtop. No need to change any bulbs or anything. Put them on carfully and line up the numbers and spaces correctly and run the wires and mount the control module somewhere. Run the ground to a bolt or something and then the power to the fuse box or splice a accessory wire.
Hope this helps..
mdodge is offline   Reply With Quote
Old 06-30-2004, 04:48 PM   #3
havik
These are instructions for drjracing gauges, but the install should be the same.
http://invision.aleromod.com/index.php?showtopic=13
Old 06-30-2004, 05:06 PM   #4
b-spot
b-spot is an unknown quantity at this point
^ Nope. Install is completely different.
If I did went to college...
b-spot is offline   Reply With Quote
Old 06-30-2004, 05:35 PM   #5
havik
ah, I see.
