Go Back   Aleromod.com > General Help > Paint and Body Work
Old 06-16-2009, 08:23 AM   #1
surreal_awakening
surreal_awakening's Avatar
Sheetmetal question
So I want to drill a 9/16" hole through the roof of my car to run an antenna for my satellite radio. I'm tired of the water running along the antenna wire and leaking into the car the way it is set up now. What is the best way to drill cleanly through the sheetmetal. I haven't had the best of luck with that "cleanly" part in the past. Suggestions/tips/etc?
Old 06-16-2009, 08:46 AM   #2
CactusWill
Just buy a regular antenna mount. It has a seal and doesn't leak.
Old 06-16-2009, 09:07 AM   #3
surreal_awakening
What exactly are you referring to by "regular antenna mount"? The sat radio antenna has a wire run through my door jamb to the cabin of the vehicle. Water is slipping past the weatherstrip that way.
Old 06-16-2009, 09:15 AM   #4
CactusWill
I'll get a pic of one later this week.
Old 06-16-2009, 04:47 PM   #5
Caboose73
stick it to the inside of your rear window thats how i have mine cause i got sick of the water leaking in
Old 06-17-2009, 07:08 AM   #6
surreal_awakening
Do you notice any difference in reception that way?
Old 06-17-2009, 11:03 AM   #7
Just go slow with the drill and use a smaller size then go larger.
Do you have a factory XM antenna that you're using?
Old 06-17-2009, 11:36 AM   #8
surreal_awakening
No, I was going to get a marine style Sirius antenna, unless a factory XM antenna will connect to and work with my Sirius receiver.
Old 06-17-2009, 11:40 AM   #9
Yeah, it works fine with the XM antenna on sirius.
Old 06-17-2009, 11:41 AM   #10
surreal_awakening
Maybe I'll look for a factory antenna on fleabay then.
Old 06-17-2009, 03:02 PM   #11
Noseminer
Noseminer's Avatar
Noseminer is on a distinguished road
With mine i just ran it down the weather strip. Mine had a small lip that pulled back on the weather strip, and i just tucked the wire in there and ran it down the door then around to the dash.
Noseminer is offline   Reply With Quote
Old 06-17-2009, 05:12 PM   #12
NONE
NONE's Avatar
NONE is on a distinguished road
step bit, if you have one.
NONE is offline   Reply With Quote
Old 06-17-2009, 05:55 PM   #13
Caboose73
Nope works just fine and i also have an xm antenna plugged into my sirius
Old 06-17-2009, 07:45 PM   #14
surreal_awakening
Go slow with a step bit and an XM antenna will work...good info guys. Will have to evaluate inside of the window vs. drilling now. Thanks all.
Old 10-10-2009, 08:44 PM   #15
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
Dont drill anything, just run the anti. out the back and up to the rear trunk.
A57 is offline   Reply With Quote
Old 10-10-2009, 09:13 PM   #16
surreal_awakening
I'm long past this now. The car will be in the scrap yard by the end of the month. But thanks anyway.
Old 10-10-2009, 10:50 PM   #17
was wondering why no-one else mentioned this... but obviously... this can be closed now.
Old 10-11-2009, 12:37 AM   #18
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
pull up the seal and tuck it into it and run it thats what i did with my nav antenna, no problems... ill get pictures tommorow.
NVM i skimmed before i read it all.
Ian 2000GL LA1 is offline   Reply With Quote
Old 10-13-2009, 11:06 AM   #19
zzyzzx
zzyzzx's Avatar
if you want to see what would happen if you tried drilling through the car, you can get all the practice you want now.
Old 10-13-2009, 11:09 AM   #20
surreal_awakening
True enough
