06-23-2009, 12:19 AM
Cold Air Intake Question? Cavalier or Alero
I have a 2.4 alero with 5 speed trans, and was wanting to put a cold air intake on it. I have found this one on ebay, however it is for a 2.4 cavalier same year and it is a wai but advertised as cai, I was wondering do you think it will work??I know I will have to seal the current iat hole on it and drill a new one but mounting is my main concern. Any one tried this? Do you think this one will work? I will be using a diff filter cause this one is crummy, but the pipe is the main reason im buying it and because it is cheap. Thanks
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
06-23-2009, 02:06 AM
if not you can make it work. its not hard a kit is not neccessary just easier
cause all you need is pipes, clamps connecters and a filter
06-23-2009, 03:17 AM
OptionRacing make a cold air intake for the 2.4L cavalier its about the same price, and its actually a CAI.
http://www.optionracing.com/features...jsp?itemID=209
1999, RED Alero GX
06-23-2009, 06:28 AM
Yea I wanted to kinda stick with a WAI after some of the reviews i read on cai vs wai. So will any 2.4l cavalier intake work with an alero 2.4?
06-23-2009, 02:52 PM
Canada's Ghost
yup it sure will, check out cosmoracing.com they're a company out of Quebec alot of guys on this site with both the 2.4L & 2.2L have there intakes myself included.
06-23-2009, 04:47 PM
thats what i have and it fit perfectly, and the filter was even pretty good. i did switch to a k&n tho.
06-23-2009, 08:15 PM
Ok sweet, just bought it. I read cai vs wai and the debate is endless. However some guy made a wai that warmed his intake through his exhaust heat and recorded a higher mpg without no power loss. He said full open throttle= cai is the way to go however is throttle is readily applied=wai will give you car more power. I found that really interesting. Everyone has there own opinion though! thanks alot for the advice guys!
06-23-2009, 08:31 PM
One last bit of advice, can i splice and add wire to my iat sensor or will that trip off somehting and make it not work? Just in case i cant reach the spot for the new intake.??
06-23-2009, 11:40 PM
To make an actual "Cold air intake"....which removes all the plastic stuff....you get the WAI from a Twin Cam and the Cold air intake from a 3400 engine and put them together....AND you have a cold air intake system.
06-24-2009, 01:02 AM
Hmm that i might do later on, still need advice on the iat sensor splice? Is it do able, will it work even after i elongate it with about 4 inches of wire?
