Old 06-26-2009, 03:40 AM   #1
acat550
acat550 is on a distinguished road
To cut the wire or to not cut the wire?
Im putting in a new air intake but need to know if i cut my iat sensor and extend it, will it stop working or work flawlessy? Anyone have any expeirence with doing this? Will it work?
acat550 is offline   Reply With Quote
Old 06-26-2009, 08:24 AM   #2
if you know how to solder, then it will benefit you to cut it, and extend it a few inches. just use some good heat shrink tubing to keep it protected
Old 06-26-2009, 10:26 PM   #3
whiterider00
whiterider00's Avatar
i needed to do the same thing, and at this point, its not soldered, just used those connectors where you slip both wires into it and clamp down, i forget what theyre called. anyway, i occasionally get issues with rough shifting, which is almost certainly caused by what i did to the wire. so in short, yes you can cut and extend it, but make sure you solder it and use the same gauge wire.
Old 06-26-2009, 10:29 PM   #4
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
So sensors are just electricity,resistance?!?
some pictures
http://leoalero.monchar.com/
leoalero is offline   Reply With Quote
Old 06-26-2009, 10:42 PM   #5
^thats what the signal is sent as, yes. differnt conditions create a different resistance.
Old 06-27-2009, 01:09 AM   #6
wrestlingandrunning
wrestlingandrunning is on a distinguished road
http://www.pfyc.com/pc/GN3002/ALUNDE...9+Harness.html
wouldn't this just be easier?
wrestlingandrunning is offline   Reply With Quote
Old 06-27-2009, 11:25 PM   #7
whiterider00
yes that would be much easier, and had i seen that when i cut my wires, i would have gone that way. also, i just soldered everything back together, and it does seem to have made a little bit of a difference in my shifts. not quite as rough anymore. but ya the easiest thing to do would be get the harness, and cheapest would be splicing in more wire, unless you seriouls screw something up and need to buy new shit.
Old 06-28-2009, 12:22 AM   #8
wrestlingandrunning
well if you by chance mess something up and need to redo i guess it's there for you
