Old 07-04-2009, 05:11 PM   #1
Pacho
Disabling 3057 Front Turn Bulbs
How would I go about disabling the 3057 turn signal bulbs on the front when I'm not using them. I want them only to light up when the turn signal or hazard is engaged, not when I'm driving at night.
I already have the DRL's disabled using the relay trick, I imagine I would have to do something along the same lines to disable the 3057's when turn signal/hazards aren't engaged.
Old 07-04-2009, 06:14 PM   #2
pretty sure that's not legal
Old 07-04-2009, 06:17 PM   #3
AtomicX
AtomicX's Avatar
How come your farest ones arn't on?
Old 07-04-2009, 07:29 PM   #4
Psyfox
Psyfox's Avatar
Psyfox is on a distinguished road
What my buddy did (and what I have yet to do) is this:
Since there are two filaments in that bulb (one controlling the running lights and one controlling the lights that flash when you turn), what you can do is just pull out the bulb and put a small piece of electrical tape over the filament that controls the running lights and then reinstall. It's pretty easy, and it worked on my friend's Mazda 3.
Like I said, I haven't done it YET, but when I do (which might actually be done around Sunday or so) I'll let you know and tell you how it went (and of course provide pictures).
And red, you're right, it's not legal, but neither is clearing your corners :P, so whatever...your call.
2001 Oldsmobile Alero GLS Coupe (black, 3.4L v6)- show car/college car project
Pictures can be viewed here: http://s10.photobucket.com/albums/a1...20Alero%20GLS/
Psyfox is offline   Reply With Quote
Old 07-04-2009, 08:17 PM   #5
tape? idk man that sounds shabby like using stockings to smoke ur tails
Old 07-04-2009, 09:40 PM   #6
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
Or just take a pair of wire cutters and trim off one lead to the outer filliment.
One Bolt at a Time.
Blktrax is offline   Reply With Quote
Old 07-05-2009, 12:42 AM   #7
yea just disable the running light filament.
Old 07-05-2009, 01:48 AM   #8
Pacho
good call psyfox, i'll see how yours turn out.
atomic, somehow they disabled themselves when i disabled the drl's-maybe someone else would be able to explain this better.
Old 07-05-2009, 02:40 AM   #9
Atmosphere
Atmosphere's Avatar
Atmosphere is on a distinguished road
Can you explain how you disabled your DRL's? Everything I find seems to result in a SES light. Also, do you have HID's?
2K 3.4L 4DR GLS
Atmosphere is offline   Reply With Quote
Old 07-05-2009, 03:17 AM   #10
Pacho
Yes I have 6000 K HID's from http://www.carhidkits.com/oldsmobile...o-hid-kit-327/ I got the $79.99 version for 9006 bulbs (low beams) and after seeing the difference from halogen, I'm ordering the 9005 bulbs (high beams) in the next few days.
I disabled my DRL's using these instructions: http://www.aleromod.com/forums/showt...isable+drl%27s
I put a piece of cardboard in between the contacts of the relay. Make sure you are using the correct relay...the person writing the thread stated relay #24. I will check in my fusebox tomorrow to make sure that's the right one.
Old 07-05-2009, 10:14 AM   #11
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i think cleared corners is legal because they're putting amber bulbs in space of the amber lens, im pretty sure a Buick came stock with completely clear headlights, the turn signal portion just lights up amber
these are amber 194 bulbs for an FYI in case anyone asks,
Old 07-05-2009, 10:16 AM   #12
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
http://tbn2.google.com/images?q=tbn:..._headlight.jpg
http://tbn2.google.com/images?q=tbn:...dlight-480.jpg
Old 07-05-2009, 10:20 AM   #13
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
does that one actually light up amber i went ahead and bought the amber colored ones the other night when one of mine went out
Old 07-05-2009, 10:48 AM   #14
RisenequinoX
RisenequinoX's Avatar
RisenequinoX is on a distinguished road
Send a message via AIM to RisenequinoX Send a message via MSN to RisenequinoX
so are you saying you want them to be completely shut off or, do you want like a relay so you can turn them on at your own will?
and AR, triple post FTL.=]
100,000 Mi 3/29/2011
RisenequinoX is offline   Reply With Quote
Old 07-05-2009, 11:38 AM   #15
Pacho
the picture of the 3057 bulb above is white, the amber 3057's have an orange coating on them.
RisenequinoX-I want the 3057 amber bulb disabled when I'm not using the turn signal or hazard lamps. Look at the picture at the very top and put your finger over the part that's lit up amber. It would look better with the amber not lit up at night.
I'm going to disable the running light filament and post up the correct relay for disabling drl's later on today.
Old 07-05-2009, 11:53 AM   #16
Pacho
Relay #22 is the DRL relay, NOT 24.
Old 07-05-2009, 04:17 PM   #17
AtomicX
AtomicX's Avatar
Hm I took out relay 22 and made it so #87 (the middle prong) didnt touch anything, i even bent it so it didnt go in the hole, but still my DRL's are on?
Old 07-05-2009, 04:20 PM   #18
Pacho
from the above link i posted:
slip peice of folded paper between the bottom most contacts (there is a contact in the middle of 2 contacts.. it will be touching the top contact.. slip the the paper between the middle and bottom contact.. it should be open... this will prevent the middle contact from moving down and touching the bottom contact when your car is on, thus preventing your drls from turning on
Old 07-05-2009, 04:22 PM   #19
AtomicX
AtomicX's Avatar
Im really confused by that
Old 07-05-2009, 06:49 PM   #20
NONE
NONE's Avatar
NONE is on a distinguished road
i just pulled out my drl relay, do drls no problems
NONE is offline   Reply With Quote
