yea good call freeze......i would say its eitherthe fans are gone or the wiring after the relay may be grounding out, im leaning more towards the wiring because you are blowing fuses even with a greater amperage rating.......but yes check the fans first, if they work then id say take it to the dealer (if you have the warranty), if not and you are very handy you can give it a look urself.....
