Old 08-04-2009, 12:00 AM   #1
dontunderestimate10s
dontunderestimate10s is on a distinguished road
loudest dbs you got??
whats the loudest bds uve hit in your alero? or in your team or other vehical u have a part of? please state the meter used if u can!
alero= 2 ten inch diamond tdxs hit 145 on termlab
alero single 12 massive dmx hit 149.7 on an older audio control
(powered by 2 p3000.1s)
alero= 3 8w7s hit a 145 termlab
all of these were in the trunk behind the b pillar.
team truck, TOXIC-CREATIONS (stereotown) 170.3 bds on termlab.
lets hear your scores and how you did it!
dontunderestimate10s is offline   Reply With Quote
Old 08-04-2009, 12:04 AM   #2
and i totally meant dbs, i just cant type tonight
Old 08-04-2009, 12:25 AM   #3
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
I like your username
Fi-Alero is offline   Reply With Quote
Old 08-04-2009, 02:07 AM   #4
Cashdollar2009
Cashdollar2009's Avatar
Two 15" Petra Prowlers (mid-1990's subs) Sealed Enclosure
Visonik v308xt (Amplifier i picked up for $34.00 brand new)
4 ga. Wiring, 500watts rms
dB Drag = 141.5dbs...
Under construction...
Old 08-04-2009, 06:40 AM   #5
ha ya i should change it to 8s tho
Old 08-04-2009, 03:22 PM   #6
Fi-Alero
Fi-Alero's Avatar
I've done a few mean things with some 8s lol.
I believe I have the loudest metered aleros
Old 08-04-2009, 03:23 PM   #7
aren't you suppose to post what you metered at?
Old 08-04-2009, 03:29 PM   #8
Fi-Alero
Fi-Alero's Avatar
First setup:
Hifonics 1206d on a 15" FiSSD: 143.2db @ 32hz
Another few setups:
One RD 1750.1 on a 15" DD 9515: 148.3db @ 51hz
Two RD 1750.1s on a 15" RD HW: 151.1db @ 57hz
Current setup:
Two RD 1750.1s on two DD2500 series 10"s : 150.0 @ 57hz (still working on getting this setup louder )
Also I have helped build a van for our team/shop:
http://www.aleromod.com/forums/showthread.php?t=28231
Old 08-04-2009, 03:47 PM   #9
First setup:
Another few setups:
Current setup:
curious do you open ur trunk since its facing and ported forward?
Old 08-04-2009, 03:48 PM   #10
and are they all termlab scores im assuming?
Old 08-04-2009, 03:50 PM   #11
my alero has been having electrical issues and has blown up 6 decks and 3 amps. so no more system in this car. there will be a system in my new evo tho
Old 08-04-2009, 03:50 PM   #12
StoopidAlero
StoopidAlero's Avatar
StoopidAlero is on a distinguished road
In my ex's cavy, we had 6 Memphis Pr-10s with a Class d majestic.
Stock SPL -- 144.5 on the old school mics. Probably 2001-2002ish
Then we had 2 Memphis 15" Mojo's with 2 class d majestics
Modified SPL -- 147.3
My single cab s10 with 4 Sony Aluminum cone 10s and the class D majestic
Stock SPL -- 142.2
These numbers were all from 2000-2002ish. Back when you could slap together just about anything and get huge numbers. Id say these days those numbers would be off by about 3db. I miss those days. Won alot of shows with the cavalier and amazed many with the 4 10s in a reg cab s10
StoopidAlero is offline   Reply With Quote
Old 08-04-2009, 03:54 PM   #13
Stock SPL -- 142.2
did you do a blow thru in the s 10? thats what were doing, we have put 6 boxes in now and cant get the tuning right. 4 twelve inch powerbass 3xls and a powerbass xta 5000. if anyone knows haw to tune a v shaped box please share. im no noob either
Old 08-04-2009, 04:08 PM   #14
Fi-Alero
Fi-Alero's Avatar
Yes.
Yes. I'm actually .8db louder with the trunk barely popped.
I'm assuming this is a single cab s10?
Old 08-04-2009, 04:16 PM   #15
Yes.
yes it is,but extended would have been nice.
Old 08-04-2009, 04:47 PM   #16
StoopidAlero
No blow thru, completely stock with the exception of the jack removed from the back wall. And I think I have a program somewhere on my computer for tuning all kinds of crazy boxes. Basically you just type in the dimensions of your box and it would give you the tuning frequency. I think it had a way to calculate something for a V shaped box.
Old 08-04-2009, 05:52 PM   #17
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
132 but its mostly out of the car right now, not even going to go into all that I had. But right now just the one 12" and on 1500 rms amp that sounds louder then all the other crap that I had, I will get tested on the 16th at post.
Testing from termpro http://dbdragracing.com/ with this guy as the head judge http://www.youtube.com/watch?v=z-w7YIf32oM
Afugy is offline   Reply With Quote
Old 08-04-2009, 07:26 PM   #18
Cashdollar2009
Hey he was at the show in Butler where i got mine metered! He's returning world champion in bassrace.... He won, hit 159.9 all three runs...
Old 08-04-2009, 07:39 PM   #19
ya we do to, but the v shape is acting as a port itself, so its like the port is starting at 5 inches and keeps expanding. wehave been expeirimenting w placing boards in the shape of a v within the v to keep the port opening the same size, but then that adds to our length and blah blah blah... last year we were doing fiftys w 2 twelves at like 58 hertz and now were doing 50s at 27 hertz, its low as shit and sounds loud as hell but we want it tuned to 58 which is the tuning of the actual vehical. we should be doing some good numbers if we can get the box tuned correctly.
Old 08-04-2009, 07:45 PM   #20
we would just make a normal slot ported box except there really isnt enough room to face 4 woofers across and a port. we were considering using port tubes bc thats easy to tune, but cant really fit any decent size. considering experimenting with triangle shaped ports, were not sure how the triangular shape will effect the bass waves tho. allowing them to open up and what not. if anyone has any input im always open to ideas!!
