Old 08-22-2009, 12:18 PM   #1
rida125
rida125's Avatar
rida125 is on a distinguished road
Send a message via Skype™ to rida125
Rockford Fosgate Punch XLC
Ok so I bought subs from a garage sale, I just wanted the boxes that the subs were in because i had already bought two 12in pioneer, but in those two boxes there was 12in Rockford Fosgate Punch's. SO im wondering are Rockford Fosgate any good, i dont know much about them and looking for some input.
rida125 is offline   Reply With Quote
Old 08-23-2009, 03:00 PM   #2
Valley olds
Valley olds's Avatar
Ive got the P1 10's and they're ok.
Old 08-23-2009, 05:33 PM   #3
itsbmw
I had p2s and they were good for what I payed. I payed 200 for the 2 12s in the rockford box, and a 800w kenwood amp. Nothing special at all. but it worked perfect for the price.
Old 12-01-2009, 04:27 PM   #4
rida125
rida125's Avatar
Ok so on the bottom of these subs it says 8 Ohms, what does that mean, and does anybody know what the specs are for these ones?
<img src=http://i896.photobucket.com/albums/ac167/rida125/beach5-1-1.gif border=0 alt= />
Old 12-01-2009, 05:01 PM   #5
Valley olds
I believe 8 Ohms is the resistance in the sub's coil. I don't know if you have seen amps that say __Wx2 @4ohms (Usually around double of 4)wx2 @2 ohms. Well thats what its for, only yours are 8. Depending on how you wire them though, you will get different loads of resistance.
Old 12-01-2009, 05:08 PM   #6
RF are pretty good subs, at least the newer ones are.
8 ohm is quite a bit for a sub. when you look at the power output of amps, look for the rating at 8 ohm. now if it was dvc, you could prob wire it for 4 ohms and have more amp options available easily.
Old 12-01-2009, 06:22 PM   #7
If you got two 8 Ohm subs with only a single voice coil you can wire them in parallel for a 4 ohm load.
So whatever WRMS you need, look for it XXX WRMS x 1 @ 4 Ohms.
Old 12-03-2009, 11:48 AM   #8
rida125
rida125's Avatar
ok so does anybody know how many Watts you need to get these guys. i have been trying to find the specs with very little luck. could you use the 8 Ohms to figure out the max watts and the rms?
Old 12-03-2009, 12:18 PM   #9
Valley olds
Which model rockford subs are they?
Anyways, here is a bunch of old manuals. Just go into the year of sub, and the manual should be in there. http://www.rockfordfosgate.com/rftech/library/
