Old 08-23-2009, 01:00 PM   #1
irondiezl3
irondiezl3's Avatar
anyone know the wires for the dimmer wheel?
i see four wires on this grey white black and yellow i think either yellow or green. i need to know what colors to run my positive and negative to for my leds i installed under the dash? any help appretiated thanks.
i could also tap them into the guage harness to come on when it gets dark out too cant i? i believe those ones are grey and tan correct? tan beingthe negative?
Old 08-23-2009, 01:18 PM   #2
gray is accessory lighting wire. controlled by the dimmer, turns on at night.
all solid gray wires in the dash are this.
for ground.. use any ground. even if you make your own.
Old 08-23-2009, 01:56 PM   #3
irondiezl3
irondiezl3's Avatar
so gray for positive on leds and black or metal ground for negative cant i just tap into black wire on dimmer switch?
Old 08-23-2009, 02:43 PM   #4
yes. correct for all
Old 08-23-2009, 03:25 PM   #5
irondiezl3
irondiezl3's Avatar
got em working just wierd they flicker with engine at idle.
Old 08-23-2009, 05:09 PM   #6
Check your ground
Old 08-23-2009, 05:17 PM   #7
irondiezl3
irondiezl3's Avatar
is there something under the driverside dash that could be making close contact with bulb causing it?
Old 08-23-2009, 05:30 PM   #8
Now that I think about it if you have led's running off of the dimmer switch depending on what voltage they require there may not be enough if you have the lights dimmed. Have you tried the lights with the dimmer all the way up in the on position? Do they flicker then? If not when you dim them do you notice that they flicker more the more you dim the lights? What kind of led setup are you running?
Old 08-23-2009, 06:40 PM   #9
irondiezl3
irondiezl3's Avatar
they get brighter if i click the wheel all the way up. if i even attempt to lower the dimmer they basically get so dim they turn almost off but i have the same led bulbs everywhere else in my car and they dont do that they dim down as i dim the wheel down only these two i just put in do the flicker and get brighter if i click it all the way up? they are 5 led 194 bulbs. i bet ur right cuz when i had them wired to the cigarette lighter they didnt flicker.
i noticed if i do anything that uses power they get dim like windows turn air on even brake. again wierd because my guages r connected same wires and they dont do it maybe ur right maybe i gotta try regrounding them maybe the grounds on the actual bulbs are not tight and clean enough idk if that would cause flickering and dimming though but its gotta be sumthin with these cause they are the only bulbs doing it.
Old 08-24-2009, 08:22 AM   #10
If they are the only ones doing it and they worked fine when connected to the cig lighter then it sounds like those bulbs aren't going to work off of the dimmer switch. You can try grounding else where and make sure the paint is off exposing the bare metal then ground the wires there. Also check your positive tap point to make sure that you have a solid connection. Are these wired in series or parallel to the circuit? This could have something to do with it as well.
Old 08-24-2009, 09:09 AM   #11
also keep in mind... leds are VERY voltage sensative. i know mine dim when i roll up my windows, at idle.... but thats because my voltage is dropping due to the big power draw.
and dip in voltage, will result in them dimming slightly. halogens don't do this.
Old 08-24-2009, 12:13 PM   #12
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
Upgrade charging system for LEDs? lol
Fi-Alero is offline   Reply With Quote
Old 08-24-2009, 03:24 PM   #13
irondiezl3
irondiezl3's Avatar
im gunna redo the positive and make a new clean perfect ground and see if that works. the way they flicker with the engine so sensatively makes me think its just a bad ground eiher on the bulb or wire so ill try rewireing then try diff bulbs maybe this weeken and post if that helped thanks for advice i appretiate it!!
