Old 09-12-2009, 11:25 AM   #1
worknprog.99
worknprog.99's Avatar
amp?
ok so the other day i nticed my sub was being rather weak, then started cutting in and out.. then last night it worked perfectly fine and i got home and no bass at all.. the sub has continuity so i dont think its that, i ripped the radio out the rca cables and remote wire were fine i checked all fuses and connections.. so im thinking the amp went bad... is there a way to confirm this or just assume it?
Old 09-12-2009, 11:30 AM   #2
MotorCity
MotorCity's Avatar
MotorCity is on a distinguished road
idk sry
I am beyond help...
MotorCity is offline   Reply With Quote
Old 09-12-2009, 11:34 AM   #3
the way to confirm.. is to replace it, and see if the new one is doing the same as the old..
Old 09-12-2009, 11:38 AM   #4
are any wire loose or disconnected on the amp is the fuse on the amp bad or the fuse on the 12v cable the ports were the rca cables that go in the amp might be blown what are u running for the RMS of the sub and the RMS of the amp.
Old 09-12-2009, 12:02 PM   #5
worknprog.99
is there a way to just test to see if there is power comming frm the output terminals to the sub? maybe with like a continuity tester?
Old 09-12-2009, 12:03 PM   #6
Digital Multimeter. set it to AC power.
Old 09-12-2009, 12:41 PM   #7
Could just be a loose connection or a fuse going back.
I would check all power/ground connections to the amp. Pull them apart and put them back together. If it still aint right replace the fuses in the amp and on the power wire.
If that has no effect than more than likely theres an issue with them amp.
What amp is it?
Old 09-12-2009, 02:01 PM   #8
worknprog.99
im pretty sure its the amp. its not a good one anyways but it sounded good while it lasted lol.. it was a boss
Old 09-12-2009, 02:27 PM   #9
lol, probably right.
Get me a budget and what kind of power you need. I will see if I have something that will work for ya.
