09-15-2009, 05:02 PM
Wtf?????
i tried replacing the ignition coils when all of the sudden there is gas spraying out of the engine, i turn the car on and feul is flowing out of the fuel rails and all over the ground, I DO NOT KNOW HOW THIS HAPPENSS!?!?!?
09-15-2009, 05:03 PM
probably because the fuel rails are under pressure, and even when they're not, they will leak out if you wiggle the injectors loose or the fuel rail
so if you're taking them off or whatever, this is to be expected
09-15-2009, 05:05 PM
ughh i tried pushing it back into place but it just keeps popping out and spraying gass all over my garage
09-15-2009, 05:11 PM
The coils shouldnt have anything to do with that problem...
09-15-2009, 05:19 PM
idk sry
I am beyond help...
09-15-2009, 05:44 PM
Anytime you work by the fuel rails or on them you should 1st releive pressure by undoing the gas cap and pulling the fuse for the pump and then running until the car stops. Then you are good to go.
Have a good day
09-15-2009, 05:47 PM
ok, ill relieve the pressure in the fuel rails and see if it works.
09-15-2009, 05:48 PM
Re;
Um did you accentdently pull on the fuel rail while changing the coil pack?
as ion said just push it back in.. if its pop out again, then you need to push alittle hard till you feel it pop into the lower intake.
if you need more help pm me..
09-15-2009, 05:49 PM
lol i wasnt touching the fuel rail in anyway at all, it just did it on its own, idk how haha
09-15-2009, 05:50 PM
thats wierd.... fuel injectors just dont pop out..
09-15-2009, 05:51 PM
Female.
PHANTOM FUEL RAiL
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
09-15-2009, 05:54 PM
lmao ya i have no idea how it happend. maybe the heat from the engine?
09-15-2009, 06:12 PM
No...
It mysteriously dont blow leaks.
It must off been leaking?
