Old 09-15-2009, 07:14 PM   #1
Blueolds
Blueolds's Avatar
Blueolds is on a distinguished road
how to?
A couple days ago i bought new spark plugs and have been trying to change them and before you say anything yes i did use the search button well for the life of me and cant get the boots over the spark plugs in the back off i just cant get the leverage to pull them off and it doesnt help that they've been on there or 9 years any tips on how to get them off.
Blueolds is offline   Reply With Quote
Old 09-15-2009, 07:21 PM   #2
Vella's Alero
Vella's Alero's Avatar
Vella's Alero is on a distinguished road
when i bought mine it was the same thing. The original factory ones were still in there.
To get the back three off i ended up taking out the alternator and then i had enough leverage to pull them out.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
Vella's Alero is offline   Reply With Quote
Old 09-15-2009, 07:23 PM   #3
bkathsalero
bkathsalero's Avatar
bkathsalero is on a distinguished road
Send a message via MSN to bkathsalero
A needle nose pliers is your friend!!
bkathsalero is offline   Reply With Quote
Old 09-15-2009, 07:30 PM   #4
Blueolds
Blueolds's Avatar
Needle nosed pliers seem allitle to aggressive, would'nt they harm the boot?
Old 09-15-2009, 07:33 PM   #5
Blueolds
Blueolds's Avatar
I'll give that a try!
Old 09-15-2009, 07:35 PM   #6
bkathsalero
It's what I used when I first started as a tech, before I got a spark boot pliers. Just grab in the middle of the boot. And you should probably get new wires anyway. Chances are that because there so old the metal internal piece of the boot will stick on the plug.
Old 09-15-2009, 07:52 PM   #7
Blueolds
Blueolds's Avatar
Valid point but i am unemployed not made of money so i try and keep costs to a minimum.(call it cheap)
Old 09-15-2009, 07:55 PM   #8
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
WIGGLE THE BOOT< THEN, Twist the boot, then pull... just breaking the seal from all the heat and the lack of grease on the boot.......
good luck.....
A57 is offline   Reply With Quote
Old 09-15-2009, 08:04 PM   #9
Those wires need to be replaced.
If you can get a can of WD 40 back there it makes rubber real slippery. Use it on hoses all the time. Easy on, easy off.
Old 09-15-2009, 08:36 PM   #10
colonel6632
colonel6632's Avatar
ya... did my friends 3100 series motor... two wouldn't come off and when they did the wires were effed... so just put new ones on.
