Old 09-28-2009, 12:01 PM   #1
02AleroEco
02AleroEco is on a distinguished road
Send a message via AIM to 02AleroEco
Interior lights
ok so, my map lights and dome light are usually off when i drive. obv. but now even when i drive and have the dome light set to door, it stays on, aswell as the map light under the rear view mirror. yeah they stay on, even when set to off. whats wrong??? the fuses were changed but still happened. is it a relay?
02AleroEco is offline   Reply With Quote
Old 09-28-2009, 01:24 PM   #2
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
um... do you have the dimmer switched pushed all the way up into the on position?
Old 09-28-2009, 03:29 PM   #3
lonzoj90
lonzoj90's Avatar
lonzoj90 is on a distinguished road
I'm having the same problem. I unhooked the cord on the back of the rearview mirror. I havnt figured out a better fix yet
lonzoj90 is offline   Reply With Quote
Old 09-28-2009, 04:52 PM   #4
bdyman
its controled by the door latch, replace the door latch problem fixed
ya know you open the door the little light goes on
or sometimes the contact points that hold the bulb get loose, check that too, or check the dome light if its not the door latch
any service vehicle lights on
Old 09-28-2009, 05:03 PM   #5
AtomicX
AtomicX's Avatar
I have LED's in mine and they always stay on but they are very very dim and faint.
Old 09-28-2009, 05:13 PM   #6
the12volt.com
find a wiring diagram for it, grab your multimeter, and start checking.
Probs start with the door latches... I forget.. do our cars have a chime for every door if the key's in and door opened, or just driver's side? Same with keeping the radio on. If the radio turns off right away when the car gets shut off.. it's the driver's door. If not, IIRC, that eliminates the driver's side door at least.
Old 09-28-2009, 10:41 PM   #7
02AleroEco
i will check the dimmer again.
and no, there are no service lights.
Old 09-29-2009, 12:01 AM   #8
halogens have a high amount of current needed to "turn on" leds do not.
the residual in the circuit produces pin point light in leds... its just bad circuit design on GMs part.
Old 09-29-2009, 03:21 PM   #9
02AleroEco
the damn dimmer switch was set to on.. haha
now on this same topic. my dash, hvac, and shift console lights do not work.. fuse is fine. i realized that putting in led bulbs of a diff wattage blew something. can i repair this?
Old 09-29-2009, 03:25 PM   #10
um...
leds of a different wattage? leds use LESS power, not more. more = blown fuse. less = nothing
what lights did you change? double check fuse in the top right of the passanger fuse box, as well as the ones under the hood.
Old 09-29-2009, 04:40 PM   #11
ok this is gonna sound dumb, but since you somehow left your dimmer switch on all the way for the lights to be on, did you by chance have another brain fart and turn the dimmer switch all the way down now?
Old 09-29-2009, 04:45 PM   #12
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
LOL thats just a bad day.
Ian 2000GL LA1 is offline   Reply With Quote
Old 09-29-2009, 10:19 PM   #13
02AleroEco
ive had a bad year hahaha.. but no they havent worked for awhile, and ive been trying different things. the switch isnt the issue for this one. and if the fuse in the pass side box was blown then the dome light and map light wouldnt work, now would they haha..
as for the hood, what fuse(s) do i check? i always went by the assumption that the pass side was the only interior light fuse.
Old 09-29-2009, 11:34 PM   #14
no, there is definitely one under the hood too. don't know what # it is. use the search.. its been covered before.
also.. you DO know leds are polar, right? as in... only work one way...
Old 09-30-2009, 06:57 AM   #15
i found that out the hard way once, put together many many LED's, and i just, put them together, whoops
Old 09-30-2009, 03:15 PM   #16
02AleroEco
they were the 194 led bulbs.
i had them on as bright as they could go, then one started blinking constantly, then they all just went out, and even the stock ones wont work, which is why i figured i fried somethin, cuz i honestly never knew that there was a fuse in the hood for the interior lights, but im looking it up as we speak then im gonna go check
Old 09-30-2009, 03:27 PM   #17
02AleroEco
So it was a maxifuse, #2. and it was fine, i tried switching with another maxi, and everything still worked the same like before, still no dash or hvac lights...
Old 09-30-2009, 04:00 PM   #18
then you have a short.
now just need to know where...
1) check voltage at the bulbs
2) check voltage at the dimmer
3) check voltage on the passanger side fuse
see where it is that your losing it.
and flickering means 2 things. the LED is burning out.... or you have a bad connection. bad connections usually mean a bad ground somewhere.
Old 09-30-2009, 10:18 PM   #19
02AleroEco
voltage at dimmer was fine, and its a new fuse, ive yet to check voltage at bulb.
Old 09-30-2009, 10:31 PM   #20
i don't mean check the device... i mean check the connections for voltage. if there isn't any, the short is before that spot, if they do, then its somewhere after.
