10-14-2009, 07:18 PM
blinker clicker
alrighty. just started happening today.
when i start the car, everything goes as usual, then i turn on a blinker, and it clicks, like it's supposed to. when i turn the blinker off, it doesnt stop clicking, in fact, it clicks more rapidly. sounds like its coming from the hazard lights button, but i could be easily mistaken. any help on this would be appreciated. i want to make it stop. it's going to drive me insane.
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
10-14-2009, 07:31 PM
Let's Play Army!
the hazard light button is where the relay for the flashers is. my guess the switch (the steering column controller) is sticking and keeping the relay turned on for the flashing.
Originally Posted by black
10-14-2009, 07:43 PM
ok thank you. so how do i go about fixing it? i need to buy a new switch im guessing?
10-14-2009, 08:12 PM
Just replace the switch, its defective... the HAZARD switch..... trust me its the issue
10-14-2009, 08:32 PM
Search you will find a how to
10-14-2009, 08:36 PM
so which is it hazard or column?
or should i just be safe and do both?
how hard is the steering column switch replacement on 1-10 scale?
10-14-2009, 08:47 PM
and where do i get a hazard switch at?
10-14-2009, 08:55 PM
10-14-2009, 09:34 PM
check out the sticky at the top of this section. It has a link to GrandamGT.com that has a perfect walkthrough for your multifunction switch in the column.
10-14-2009, 09:46 PM
is tit he multifunction switch? i would think that it would be that shit soldering job in the hazard.... dude, clean the multifunction, and then change hazard of that does not fix it
10-14-2009, 11:28 PM
before you do that though I had this same problem when I first bought mine. I changed the hazard switch and it still happened. There is a free solution that might work before you do this.
Take the plastic cover off of the steering wheel and get into the turn signal stalk (where it is housed. GM put some type of gel/ grease stuff there to make it feel smooth and if that collects any dust and moves in between the contacts then it will connect the contacts and you will get the clicker sound. Wipe it off and you will be fine. Did this a year ago and havent had a problem since. Here is a site that I used and it goes step by step with pictures... http://www.wikihow.com/Fix-Grand-Am-Turn-Signals
Hope this helps so you won't have to pay anything.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
10-15-2009, 05:25 PM
SWEET! thanks!
10-15-2009, 08:44 PM
let us know how it goes for ya and what ended up fixing it
10-15-2009, 08:49 PM
please..
mine did that clinky thing, and a new hazard fixed it
10-15-2009, 09:17 PM
it does fix some...fixed my friends as well...but it didnt fix mine...I had to take mine apart and wipe off the grease before it stopped. What might work for one might not work for another so just giving all the possiblities.
10-15-2009, 09:33 PM
the way you think, you are very valuable here
10-15-2009, 09:47 PM
Thanks...That's the way I was brought up and that's the way I am...lol
10-15-2009, 10:21 PM
You do realize it could be one of two things... I had the dealer fix my hazard due to my car being part of the recall because that was the first thing I thought of. Guess what it ended being...the contacts in the column.
If I had to guess, the break down of which issue it would most likely be would be this....80% hazard switch 20% multi-function switch.
He could be right, you could be right...but the only way White is gonna fix the issue is start with one issue and go from there.
10-15-2009, 10:52 PM
i had that prob for over a year. lived with it. suddenly went away and hasnt done it in over 6 months.
MP Racing CAI, Pacesetter Exhaust, and PCM. High flow CAT. KYB GR2 struts. Canuck Motorsport Springs. Cross drilled rotors. Stern ST18 17" rims.
10-15-2009, 11:24 PM
I replaced my hazard switch. Takes maybe 20-30 minutes to do. Haven't had any issues since.
