Old 10-20-2009, 08:17 AM   #1
Ttop191
Ttop191's Avatar
Need Help Now!
ok. im late for school and my car is acting out wicked bad.
Last night i Pulled of the piece that says 2.4 Twin Cam, removed the 4 bolts, unplugged it and cleaned it up with a grill brush
put everything back last night, but when i got up this morning to start my car it started really hard, and when running it makes horrible noise
cant really describe it too well on here but its kind of like whom whom whomwhomwhomwhom whom whom whom, just keeps repeating slowly then a quick spurt of fast ones
it seems like the whole engine is vibrating, and u can hear it out the exhaust too
someone please explain
Ttop191 is offline
Old 10-20-2009, 08:21 AM   #2
You made a spring inside the boot fall out. Find it and put it back in so you're running on 4 instead of 3 cylinders.
Inside the black rubber/plastic boot that's on the bottom of the white coilpack housing is a small spring which is what makes contact from the electrical connection inside the boot to the spark plug top.
[ion] C2 is online now
Old 10-20-2009, 08:23 AM   #3
Ttop191
Ttop191's Avatar
ok thanks dude, probably screwed tho cause i was outside!
just got it apart, all springs are inside, u think they just didnt line up right when i put it back in?
Ttop191 is offline
Old 10-20-2009, 08:27 AM   #4
I found one of mine laying between the cam towers right next to a spark plug after driving a few miles lol.
Old 10-20-2009, 08:28 AM   #5
Ttop191
Ttop191's Avatar
i've got all the springs, u think it just didnt line up?
Took It off,Put it Back works beautiful
Thanks ion
Ttop191 is offline
Old 10-20-2009, 08:41 AM   #6
IRONDOG442
IRONDOG442's Avatar
IRONDOG442 is an unknown quantity at this point
Send a message via AIM to IRONDOG442
Make sure you have the ground cable going to one of the bolt holes that hold it down, if that unit isnt grounded it wont work!
IRONDOG442 is offline
Closed Thread
