Old 11-04-2009, 08:12 AM   #1
Blown 346
Blown 346 is an unknown quantity at this point
Brake light Issue.
I made a post back in march regarding a issue where my ABS and traction light were on.
After getting under the car, I noticed the two wires that come out of the hub that connect to the ABS sensor were cut. I decided to try and splice some new wires in and re connect them. Got everything connected and the ABS still doesnt work.
Does this mean I need to replace the whole Wheel Bearing on that one side along with the connector?
If so, How difficult is this to replace?
Blown 346 is offline   Reply With Quote
Old 11-04-2009, 08:26 AM   #2
colonel6632
colonel6632's Avatar
i have the same problem. my wires broke also. i spliced them and my lights are still on. i also replaced both front wheel bearings. So unless my back ones need replacing i don't think my splice worked very well
Old 11-04-2009, 08:31 AM   #3
alero_bmxer
alero_bmxer's Avatar
you need to get a new lead. i tried that but because the wire is like an angel hair doing a splice doesnt work right
Old 11-04-2009, 01:15 PM   #4
Not to mention those wires are very sensitive to interference.. The ABS wires are twisted when running through the car to reduce the chance of any interference.
