Old 11-22-2003, 11:24 PM   #1
sooper821
i've all of the sudden got some squeaking noise under the hood. i think its the belt, any opinions or suggestions??? and any suggestions on belt changing made easy on the alero??? thanks
Old 11-23-2003, 11:18 AM   #2
johny_boy32
johny_boy32's Avatar
well, first thing, open your hood....sorry for being a smart ass, once in a while the belts get dry and then squeek....put some water over the belt as it turns....usually it helps but it could be something else...try that and if that doesnt work bring it in and let a tech check it out.
Old 11-23-2003, 11:22 AM   #3
Oldsman
Owner
Oldsman's Avatar
an old trick for sqeaky belt is to take a bar of soap and rub it on the grooved side of the belt as the car is running.This is easy to do on the older cars.
There is belt dressing spray out there that is safer. I would try that.
Beware of the BackStabber
Old 11-23-2003, 03:21 PM   #4
3.4Alero
Also check the play in your belt. It should be fairly tight. If it feels loose, then your tensioner may be at the limit. That would mean you need a new belt, because it is stretched beyond the capabilities of the tensioner.
Old 11-23-2003, 07:16 PM   #5
sooper821
thanks for the input guys, i needed a new belt. got one at advance changed it myself in 10 mins. squeak is gone.
Old 11-23-2003, 10:09 PM   #6
3.4Alero
Glad to hear it. That's the easiest thing to do with belts. Don't bunny with them, just get a new one.
Old 11-23-2003, 11:28 PM   #7
Molson
Molson's Avatar
belt dressing is a bad thing for serpentine belts. It could cause it to throw off a smooth pully or tensioner. I would just replace the belt.
(It could also be a pully or accessory squeaking)
Old 11-24-2003, 10:34 AM   #8
johny_boy32
they are cheap...easy enough to just get a new one
Old 10-15-2011, 11:40 PM   #9
XanderWiFi
XanderWiFi's Avatar
Ah darn...something in my belt/pulley region is squeaking/chirping too. Not a squeal a loose or slipping belt would make. Just squeaks consistently like rotating and hitting the same "squeaky spot," not obnoxious, but noticeable.
Other tips or things to check into?
Old 10-15-2011, 11:40 PM   #10
XanderWiFi
XanderWiFi's Avatar
thread revive!
