Old 07-12-2004, 03:24 PM   #1
doggie62
Hi all .........heres hoping you can give me some advice.
My wifes car ( 2002 GLS - 28 k . 3.4 ) has just recently developed an odd steering problem.
The problem is noticable on long sweeping curves ( noticably worse when extra people are in the car) .
I can feel the steering wheel " jerk " to the opposite direction of the curve . It feels as is if the wheels are " loose and sliding slightly " and moving independently of the steering wheel. Like the wheels are trying to go straight ( again - slight pulling but very noticeable)Not noticable at all on Straight roads.
Tough to describe - hopfully you can get the jist of the problem
Tires are good - no uneven wear or bent rims. Not a tires a balancing issue ( as much as I know ).
Any suggestions for me ?? I need to get the car in to get the problem fixed b4 the warranty expires in the next 3 months.
Ball Joints ?? Tie rods ?
Any advice you have so I can stay on top of the dealer would be much appreciatted.
Thanks !
Doggie
Old 07-12-2004, 05:10 PM   #2
bigd6983
could be that........how long since an alignment?? and you also might want to check the hubs as they always go out on our cars.......
Old 07-12-2004, 05:48 PM   #3
Youngblood77
Youngblood77's Avatar
the alignment idea sounds right-on, IF it pulls to the same direction....Don't our cars have some wierd variable-rate steering set-up ? ( I realise that variable rate steering is common-place, but I heard the design they used for our cars is different ) Maybe it's a problem with that?
Old 07-12-2004, 06:09 PM   #4
jackal2000
jackal2000's Avatar
i think its pretty common in our cars for the tie rods to go, but that seems a little early with only 28k. my left outter tie rod was starting to go at like 52k.
