11-11-2009, 12:29 PM
Taking the plunge
Okay so im just going to say screw my credit card and buy a starting turbo set-up. i know the basic things ill need:
Exhaust manifolds, turbo and housing, wastegate(if not on turbo), charge piping. and oil lines(dont know how much or what size though), and the down pipe of course.
is there anything else that i NEED? if i wanted to set everything up except for the down pipe(custom). would i need anything else?
And does the outlet on the turbo housing that attaches to the exhaust manifold change depending on the turbo? same with the down pipe... like if i were to get one turbo, could i simply upgrade by just swapping them? its not a big deal, just curious for future reference.
EDIT: bov and intercooler, haha forgot those 2
Reason: adding more
11-11-2009, 12:36 PM
You'll need a blow off valve
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
11-11-2009, 01:49 PM
An extra job to keep up with the credit card bills would help. Start looking now. Good luck!
11-11-2009, 01:53 PM
Yeah, that sounds like a really stupid plan. Modding is not cheap, take care of the essentials first, then when you are in a good place financially you will be able to build something great.
11-11-2009, 01:58 PM
i have 2 thousand dollars right now. is that enough to start this project or not?
11-11-2009, 02:11 PM
New and Improved
are you doing the labor yourself?
11-11-2009, 02:16 PM
yes, ill be doing this on my own..a learning experience i guess =)
11-11-2009, 02:20 PM
New and Improved
If you shop smart, that should be enough to get it going.
11-11-2009, 02:23 PM
wideband O2 sensor for tuning, hp tuners to tune. can't drive it without a tune.
then assuming you dont roaly eff up yes
11-11-2009, 02:25 PM
New and Improved
Originally Posted by worknprog.99
roaly
is that even a word? hehe
11-11-2009, 02:28 PM
well what i intended to spell was lol... roally? roaly? royally? royaly?
i use it in everyday vocab lol... idk how to spell apparently
11-11-2009, 02:43 PM
AleroMoB
That would be "royally" bro.
2001 Oldsmobile Alero 4Dr GL2 w/ 2005 GAGT Motor
CC & PB, Tinted Tails, 3K HIDs (Lows/Fogs), GAGT Mirrors, Flowmaster Exhaust, D/S Rotors, CAI, Rockford Fosgate T400-4 T800-4, 1 15" C3, Rockford F 5.25/R 6x9
11-11-2009, 02:54 PM
New and Improved
Bahahaha.
11-11-2009, 03:22 PM
i wanna see someone go standalone fuel
11-11-2009, 03:52 PM
thats the word!!! lol
11-11-2009, 08:10 PM
anyways.... so besides a tune, would i need anything else in order to drop this in?
11-11-2009, 08:49 PM
You should start by relocating the battery. That's fairly cheap and usually necessary. Then while you are planning the other stuff, get some 28 lb. Trailblazer injectors and install them. I have a 2001 PCM program that I use which may work in your car. If you are serious about this, I can find an extra PCM. That way, you can maintain drivability as you go along, one mod at a time.
11-12-2009, 02:43 PM
ya im relocating the battery now. ill have to get new injectors and a pcm tuner
11-12-2009, 03:13 PM
where would i get a pcm program?
