I am wanting to clear the corners on my alero but NC does not allow you to take the amber out the lamp unless the bulb behind it will glow amber. I was originally under the impression that the Sylvania Silverstar 3157 model replaced both the front turn signal as well as the amber covered light but upon further inspection I noticed the bulb on the outer-most portion is much smaller than the other 3157 model turn signals. Does Sylvania make a silverstar that replaces this bulb or if not does anyone else that will appear white but glow amber.
Sylvania doesn't make a version of the smaller bulb. I just found a plain amber one at a local parts shop. Can't recall the bulb size, but there's a chart floating around here that maybe someone can point you at.
order a amber led. They are clear, but light amber.
this site has great poop, I have my whole tail section lighting in leds by them, and my front corners(the ones u are askin about)
