Old 11-18-2009, 12:01 PM   #1
bentiac
bentiac's Avatar
bentiac is on a distinguished road
245/35/19?
Can you fit a 245/35/19 without modifying the body? how about a 235/40/18? I'm going to get the 1.6" drop soon too and I have a feeling that 245 might be too much.
bentiac is offline   Reply With Quote
Old 11-18-2009, 12:17 PM   #2
a4d2a0m
a4d2a0m's Avatar
a4d2a0m is on a distinguished road
I believe that 225 is the largest width... 40/18 will fit.. but not sure about the 35/19s might be snug.
a4d2a0m is offline   Reply With Quote
Old 11-18-2009, 12:24 PM   #3
wrestlingandrunning
wrestlingandrunning is on a distinguished road
I'm pretty sure kwauck has 255, I could be wrong though
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
wrestlingandrunning is offline   Reply With Quote
Old 11-18-2009, 12:28 PM   #4
a4d2a0m
a4d2a0m's Avatar
You can do almost anything.... but he want no modification.
Old 11-18-2009, 12:35 PM   #5
wrestlingandrunning
Well when kwauck finds this he can comment
Old 11-18-2009, 12:58 PM   #6
rowdygls
rowdygls is an unknown quantity at this point
Send a message via AIM to rowdygls Send a message via MSN to rowdygls Send a message via Yahoo to rowdygls
I believe I'm running 235/35/19 but will confirm after work.
my cardomain: http://www.cardomain.com/ride/605233Alero
Chapter Member
rowdygls is offline   Reply With Quote
Old 11-18-2009, 02:06 PM   #7
hok666
hok666 is an unknown quantity at this point
Ive go the alero 442 rims and tires I hope they fit with no modification, Im guessing not.. At least I think thats what Irondogg said
hok666 is offline   Reply With Quote
Old 11-18-2009, 04:27 PM   #8
For a 245 you would need a 30 with a 19" wheel and a 35 with a 18. Same for the 235 as well. There is no closer diameter option.
Old 11-18-2009, 05:39 PM   #9
bentiac
bentiac's Avatar
Online calculator gives me those two numbers as good fits. I think I will go with 235/40/18 as I found 4 x 18 rims from a 98 BMW 325i for $200 all. It has no logo and looks kind of ugly (exactly what I'm looking for) and I just hope they are lighter than our OEM. Next I will get kumho 235/40/18 for rear and 245/35/18 for front and keep them for track only (or everywhere if I get lazy).
Old 11-18-2009, 07:32 PM   #10
The 235/40R18 is 25.4" in diameter as compared to the 225/50R16 stock size of 24.9" diameter.
However I don't know if there's any difference in the PCM for the tire size. My stock tire was 205/65R15 which is a 25.5" tire.
So basically, your speedometer may be off a couple MPH by the time you reach 60. Also make sure you have the right offset or you may rub the rear tires on the struts. My tires (235/45R17) just barely rub on the strut.
Are you planning on using the BMW wheels (FYI, no 325 in '98)? They have a 5x120 bolt pattern and typically have around a -40 offset.
Old 11-19-2009, 12:18 AM   #11
i have 255s, no modifications to the body, but i have correct offset wheels which makes a world of difference.......
Old 11-19-2009, 12:53 PM   #12
bentiac
bentiac's Avatar
Do you know what the offset is? I assume the smallest offset would work best?
Old 11-19-2009, 12:59 PM   #13
DansGen1Alero
DansGen1Alero's Avatar
DansGen1Alero is an unknown quantity at this point
Send a message via AIM to DansGen1Alero Send a message via Yahoo to DansGen1Alero Send a message via Skype™ to DansGen1Alero
Mach told me his were a +35, its in a recent post, I will look for it. He has 20s with a 235 tire
edit
here it is
http://www.aleromod.com/forums/showthread.php?t=29502
www.myspace.com/dansgen1alero
www.nicedreamscc.com
"Vinyl belongs on the side of a house not on a car"
DansGen1Alero is offline   Reply With Quote
Old 11-19-2009, 08:44 PM   #14
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
245/40/18 will fit just fine as long as you rims are not bigger than 8 inch wide.
in the rear of the alero you can fit up to a 22in rim, but a custom strut will need to be installed.
our off set is +40 or +42 on a 7.5 in rims.
goodluck.
BUILDING A V8 ALERO 2DR
A57 is offline   Reply With Quote
Old 11-19-2009, 08:56 PM   #15
my wheels are 17x8 with a +32 offset and they fit perfect with the 255 tires right at the lip of the fender...
