Old 11-28-2009, 09:31 PM   #1
mscottc
mscottc's Avatar
mscottc is on a distinguished road
wiring help
ok so i couldnt find a wiring harness for the 2001 alero locally so i found out you can use one from a 2000 so i did that and for some reason i could only get it to work by turning the lights on when i wanted my radio to come on dose anyone know why?
mscottc is offline   Reply With Quote
Old 11-28-2009, 10:02 PM   #2
Because there is no switched 12v power at the head unit due to the changes in the wiring from 2000 to 2001. The 2001-2004 head unit is controlled via the Class 2 Data Bus.
Old 11-28-2009, 10:07 PM   #3
mscottc
mscottc's Avatar
ok thanks do you know were i can get a harness for a 2001 and about how much it would be
Old 11-28-2009, 10:45 PM   #4
Chipmunk-Alero
AleroMoB
Chipmunk-Alero's Avatar
Chipmunk-Alero is on a distinguished road
Send a message via AIM to Chipmunk-Alero
Go to your local walmart and get the Schoshe wiring harness for 99-02, 04 something like that general motors. Should have Grand Am/Alero listed on the back. U still need to tap a fuse for acc power if u want it.
Someone correct me if im wrong. Im buzzed....
2001 Oldsmobile Alero 4Dr GL2 w/ 2005 GAGT Motor
CC & PB, Tinted Tails, 3K HIDs (Lows/Fogs), GAGT Mirrors, Flowmaster Exhaust, D/S Rotors, CAI, Rockford Fosgate T400-4 T800-4, 1 15" C3, Rockford F 5.25/R 6x9
Chipmunk-Alero is offline   Reply With Quote
Old 11-28-2009, 11:10 PM   #5
mscottc
mscottc's Avatar
well i got the only one walmart had and it was for the 99 and 2000 if i tap the fuse what fuse would i tap ???
Old 11-29-2009, 12:21 AM   #6
^any that has power with the key in acc or on but not when in off. you will need a tester.
