Old 12-06-2009, 02:10 PM   #1
alero_bmxer
alero_bmxer's Avatar
passenger air bag removal
Im going to be re wrapping my passenger air bag cover and i was wondering how it comes out and how long it take. any info is appreciated thanks
Old 12-06-2009, 10:45 PM   #2
If it's similar to the GMT900 PAB you gotta undo it from behind the cover, meaning you have to gain access to in the dash where the metal housing is and probably pry off the plastic tabs that hold it to the housing.
Old 12-07-2009, 12:26 AM   #3
alero_bmxer
well that sounds like no fun. maybe ill wait till spring and see if i can just find a new one
Old 12-07-2009, 12:48 AM   #4
you need to take out your glovebox to get to the screws that are inside of the dash to get it out
Old 12-07-2009, 04:09 PM   #5
sound_xtreme
sound_xtreme's Avatar
^what he said...pretty simple. like 4 bolts or something like that once the glove box is out of the way...
I have no idea what the other guy is talking about with plastic clips and shit...
Cardomain
Old 12-07-2009, 02:21 PM   #6
comanche
comanche is an unknown quantity at this point
Safety first!
If removing passenger side airbag:
Disconnect both battery cables and wait 10 minutes.
Remove glove box.
Two bolts hold the airbag in. The airbag connector is located, iirc, at the rh fuse panel access.
comanche is offline   Reply With Quote
Old 12-08-2009, 06:39 PM   #7
I am not specifically familiar with the Alero passenger airbag (produced by Autoliv), but I can give generic advice on airbag systems.. usually (at least 2010 models lol) the cover is held to the metal housing by tabs that pry off.
I used to work at Takata (Autoliv's competitor, and #1 supplier in the world of car/truck airbag systems)
Old 12-09-2009, 12:09 AM   #8
just smack into something.
Old 12-14-2009, 03:55 PM   #9
sound_xtreme
i thought the alero's were pinch welded in the middle no? meaning the top isn't removable without destruction. Pretty sure I had one that was blown out at one point and the top was impossible to remove without cutting...
Cardomain
