12-07-2009, 03:48 PM
Turn signal...
ok, this just started the other day...put on my right turn signal, and it starts blinking really fast. I figure, no prob, just the bulb needs to be replaced, so i replaced it, but still nothing. Its my understanding that it cant be the relay because then the front wouldn't blink also correct? I do have a problem with moisture in that lens, could that be the cause of the issue?
Thanks.
12-07-2009, 03:56 PM
Thanks.
You by any chance have LEDs in your turn signals?
12-07-2009, 04:04 PM
nah, regular 3057s
12-07-2009, 04:14 PM
do both bulbs blink?
12-07-2009, 04:20 PM
front bulbs blink fast, back bulb doesn't at all even after replacing the bulb...
12-07-2009, 04:29 PM
your front is fine, its a rear problem. They always blink fast when one is burnt out. Since you've replaced it, check to make sure you are getting power to the socket with either a tester or a voltmeter. if you are try another new bulb, if not you have a broken wire. with a bad fuse the front, or posibly all, woulnd't be working either, so thats not it/
12-07-2009, 06:44 PM
my guess is the back plug. somethings wrong there
12-07-2009, 07:49 PM
have you checked your blinker fluid?
12-07-2009, 07:54 PM
12-07-2009, 09:32 PM
OMG I should have known to do that! It's always the simple things that I forget about! What company is the best supplier of it?
12-07-2009, 09:38 PM
ok, i know your issue....someone used bulb grease on it... and it's blocking the connections... clean the contacts with a Qtip and like windex or something
