Old 12-29-2009, 12:30 AM   #1
rida125
rida125's Avatar
rida125 is on a distinguished road
Send a message via Skype™ to rida125
SES Light Blinking????
ok so like the title says the Service Engine Soon light has come on and blinks, here are some more details, the car is spewing out thick white smoke that smells nasty. Also the car does not go above 2000 RPMs, it just like bogs out at that. and it just dies. So what is the problem?
<img src=http://i896.photobucket.com/albums/ac167/rida125/beach5-1-1.gif border=0 alt= />
rida125 is offline   Reply With Quote
Old 12-29-2009, 12:38 AM   #2
white smoke = burning coolant.
SES = i don't know.
possible LIMG or head gasket. Ask nate about it... hes like an expert now.
Old 12-29-2009, 08:35 AM   #3
SES = i don't know.
I guess i am.
DO NOT DRIVE THE CAR AT ALL YOU RISK MUCH WORSE DAMAGE!!! DON'T EVEN START IT!! LEAVE IT WHERE IT IS
SES Blink means catalyst destroying misfire
Headgasket... sorry to tell ya bud... so you gotta do the LIMG in the process
you mechanically inclined at all? i could walk you through it
Old 12-29-2009, 09:57 AM   #4
you have a clogged cat, dont drive the car until you hack the pipe off before the cat
Old 12-29-2009, 10:13 AM   #5
don't think THICK white smoke is a clogged cat.. i think no smoke and runs like garbage is a clogged cat
Old 12-29-2009, 11:13 AM   #6
IRONDOG442
IRONDOG442's Avatar
IRONDOG442 is an unknown quantity at this point
Send a message via AIM to IRONDOG442
a blinking SES light is a general misfire not specific to a cat, it may or may not be the cat, probably isnt, the misfire could be cause by coolant pouring into the combustion chamber causing a misfire.
1. headgasket repair will probably solve the misfire and smoking issue.
IRONDOG442 is offline   Reply With Quote
Old 12-29-2009, 11:22 AM   #7
yeah, i'm guessing...
you losing coolant at all? take off your oil cap and get us pics
Old 12-29-2009, 02:58 PM   #8
lol, no
Old 12-29-2009, 05:30 PM   #9
alerored04
alerored04's Avatar
The blinking SES is a misfire. White smoke is burning coolant. Logic says head gasket. Best way to test that is a compression check.
My car breaks alot.
Old 12-29-2009, 05:33 PM   #10
Ttop191
Ttop191's Avatar
thx, you made it perfect
or attach a vacuum gauge to HVAC port, watch for vibration..
needle is steady, do a compression test
Old 12-29-2009, 08:46 PM   #11
SES light on - fix me soon
SES blinking - AHHHHHHHHHHH STOP DRIVING ME AND GET ME FIXED
Old 12-29-2009, 09:05 PM   #12
Could also be only the LIM gaskets
Old 12-29-2009, 09:21 PM   #13
how could LIM gaskets cause white smoke to POUR from the exhaust.. LIM gaskets dont pick up coolant... and are not connected to the intake (the coolant passages anyway) at all
Old 12-29-2009, 09:42 PM   #14
It did on mine, at the track. And it also had an injector stick open....
Old 12-29-2009, 10:50 PM   #15
OK so LIMG does not have any contact with coolant, but yet it's the coolant that eats away at them and causes them to rot? Coolant doesn't leak out of the LIMG area down the head and pool on the tranny or worse inside the engine to the oil?
Nate, come on now, use your head BEFORE you post
The really bad news is that the SES light started blinking on my buddy's 3100 Malibu right when the block cracked, but I bet according the Nate, that isn't going to happen to a 3400 becasue it's 2 totally different blocks :rolleyes:
Old 12-30-2009, 03:33 AM   #16
AZFire316
AZFire316 is on a distinguished road
Usually, blinking SES=multi cyl misfire. Most cars MIL's blink if more than one cyl is misfiring.
AZFire316 is offline   Reply With Quote
