12-30-2009, 12:08 AM
What do u thing about the rims?
18" Alloy Tech AT695 silver
any help with my car i will look in on and love!
12-30-2009, 01:12 AM
i thin g they'd be perfect for you, judging by the avatar
icy hot stuntaz
12-30-2009, 07:21 AM
icy hot stuntaz
WOW
i get alot of stuff about that picture....
thanx but i want nice rims 18" but black!!!
but dont have the money i am getting these plus new tires
all for 350
12-30-2009, 11:13 AM
I like the rims
12-30-2009, 11:14 AM
Whatta bargain!
Too blingy for me but then again I pay that much for just two tires....
12-30-2009, 01:48 PM
Would that be in silver or chrome? The pic is chrome but the letters say silver. If they are silver it could be ok.
12-30-2009, 08:49 PM
oops updadte ill show u guys picutes tomoro but there black and so secy with type z rims so hot and brand new tires
show pics tomoro just not on car yet
thanx
12-30-2009, 11:30 PM
not a fan of the fake rivets.....
12-30-2009, 11:37 PM
black ones look better IMO
Originally Posted by adam337
Goal - Mid 11s all motor.
12-30-2009, 11:50 PM
well thank you..
i need to now by 2 tires for the front there to big app and dont turn all the way without hitting the finder so i am going to go down from 225/40/18
to 215/40/18 think that will work?
12-31-2009, 12:20 AM
i like the silver ones myself. but i think the black ones would look hot too.
There is not such thing as too much power.
12-31-2009, 09:48 AM
I like them black better.
12-31-2009, 09:55 AM
if you have 225/40/18 tires and they are rubbing, then your wheels have the wrong offset for our application.....
you should have no problem with that tire size.....
12-31-2009, 11:20 AM
So wait what is the prob????
We put it on when it was on the lift and when we turned it it was hitting the plastic /metal in the fender well. It was just hitting the fender pintch but was touching...
12-31-2009, 11:25 AM
Ok. The car was up on a lift when you put wheels on and they were rubbing while it was on the lift?
If thats the case, then there going to rub when you get the thing on the ground and on the road.....
Right? Did I understand that correctly?
12-31-2009, 12:21 PM
i went to test them out to see if they work fine and on the lift we turned the weel to make sure it didnt touch and it was touching a fender pintch on the bottom back of the weel well
12-31-2009, 11:24 AM
what is the offset of the wheel, it should be stamped somewhere inside the wheel.....
12-31-2009, 11:27 AM
That tire size works perfectly on my Malibu also... There must be a wrong offset involved - either too far in or out depending on where it rubs first. At this size there'll be less than an inch between the tire and the spring perch on the strut which seems tight but works fine. Double-check the wheel specs...
01-01-2010, 10:14 AM
ok what could be my prob???
the left tire touches when i turn it... but i put the right one on and it works like it should... wtf
01-01-2010, 10:29 PM
post pics of the rubbing if you can... and check the inner of the wheel for the offset as posted above... this will help determine the issues at hand...
Hybrid Mode
