Originally posted by cherrington17@Jul 18 2004, 12:21 PM
parking lights work fine.Â;-) the lights behind my speedometer/tach cubby light and prnd123 are out... i'm hoping its just one of those mini blade fuses that blew on the dvr side...
U sure? Cuz they're all connected together. Your SVS (service vehicle soon light should be on too when you pop the fuse) If the parking lights (not the brake lights as in when you step on the brake pedal) on the outside still light up.. Then I think you fried your dimmer switch or worse comes a part of your BCM computer module might be fired since it senses and control the ground loop.
I think i would know. Last week, I had to fix my billet license plate frame light. It was shorting out somewhere on the frame. Everytime, I turned on my parking light, it popped a fuse. With the parking light fuse, went all of my parking (aka running lights) on the outside. All my interior dash lights, too. Took me 1 pack of 15 amp fuses, and some electrical tape and fixed. My light bulb in the license plate frame was hitting the ground on the license plate frame from the positive side of where the electricity flows to the bulb. .
