Old 01-12-2010, 04:50 PM   #1
bentiac
bentiac's Avatar
bentiac is on a distinguished road
Fan problem
My fan is no longer working when set to speeds 1-2 but 3-5 will work fine. Is this a known problem? Did a search and couldn't find anything.
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
bentiac is offline   Reply With Quote
Old 01-12-2010, 04:55 PM   #2
freeze12
Blower motor resistor is bad (common problem) it is located on the passenger side up and behind the glovebox.
...Dan...
Old 01-12-2010, 05:00 PM   #3
bentiac
bentiac's Avatar
Got the right keywords to search by now. Thanks
