Old 02-06-2010, 04:57 PM   #1
blackalero02
blackalero02 is on a distinguished road
need some help...
So we just got 3 to 4 feet of snow here. When it finally stopped I decided to start digging my car out. I accidentally bumped up against my driver side mirror and half of the mirror cracked off. I'm not about to drive around with my mirror hanging half way off. I've been doin a little searching in the threads to see if the grand am mirrors will fit directly (seeing as I like the look and need to replace em anyway). I didn't exactly get the info I needed. Will the GA mirror fit my gx? If so is there any important info I need to know about replacing these? I have manually adjusted mirrors. Any help I can get on this subject would be extremely helpful. Thanks.
blackalero02 is offline   Reply With Quote
Old 02-06-2010, 05:54 PM   #2
they manual? if they are, get manual GA mirrors, if you have power, get power...
Old 02-06-2010, 06:12 PM   #3
blackalero02
Ok and they'll fit right in?
Old 02-06-2010, 07:59 PM   #4
whiterider00
whiterider00's Avatar
ya. it has been said many many times on here before.
Old 02-06-2010, 08:20 PM   #5
Yea they will fit if you replace the whole housing, the glass its self doesn't interchange. Also the power mirrors are wired slightly different, I forget exactely how but it's like left moves it right and up is down instead. Easy fix tho or just put up with it.
Old 02-06-2010, 10:47 PM   #6
blackalero02
Ok thanks. One more question, does the trim panel where the mirror is bolted on pop right out?
Old 02-06-2010, 10:51 PM   #7
comanche
comanche is an unknown quantity at this point
Yup. Carefully!
comanche is offline   Reply With Quote
Old 02-06-2010, 11:19 PM   #8
blackalero02
Ok cool thanks man.
Old 02-06-2010, 11:46 PM   #9
DOHC_tuner
DOHC_tuner's Avatar
Simple mod.
Remove the trim panel from the inside with a flat screwdriver.
If I remember correctly there are 3 bolts. Remove them. Then just pull the mirror out with the wire or cables.
Then install the GA double post mirrors. Feed the wires or cables and connect. Fits like a glove!
Old 02-06-2010, 11:53 PM   #10
whiterider00
a sexier dual post glove...
Old 02-07-2010, 12:26 PM   #11
widbyj
widbyj's Avatar
Worked on my Malibu too! eBay was $70 for a pair a while ago. Kinda poor molding, took a while with the dremel to get rid of the seams. A little careful painting and then they bolted right on. Gotta love this cross-model stuff!
Old 02-07-2010, 10:58 PM   #12
blackalero02
Nice I got mine for $55 though. Yeah the ice cracked the mirror off the rest of the way now it's got tape holding it on so I can see where the screws and wire connects.
