Old 02-10-2010, 03:08 AM   #1
Dutchie
Dutchie's Avatar
Dutchie is on a distinguished road
No reception
Hi guys,
all of a sudden, the reception on my aftermarket radio/cd player has gone very bad.
I was told this could be due to a, forgive my english, a separation module that sits behind the back seat that separates the signal for the rear defrost and antenna. It probably is blown.
anyone knows if this is a common failure? If so, what is the proper english description and perhaps part number?
Thanks!
Buick Riviera 1970 455cu. V8 4BBL / Chevrolet Alero GL 1999 2.4 DOHC
Dutchie is offline   Reply With Quote
Old 02-10-2010, 03:20 AM   #2
Weazel
Weazel's Avatar
Weazel is on a distinguished road
Send a message via AIM to Weazel
I've had the same issue, but I've never gotten the motivation to find the problem and fix it. My rear defroster, like so many others, doesn't work, so I had always assumed it had to do with that known issue somehow.
Weazel is offline   Reply With Quote
Old 02-10-2010, 03:43 AM   #3
It's a small black box module behind the plastic of your passenger side c pillar. I think the plugs are known or to bad on them or maybe it's the module itsself I can't quite remember. Do some testing to make sure the module is getting power before you drop money on a new one.
Old 02-10-2010, 06:49 AM   #4
Dutchie
Dutchie's Avatar
That's a good one, because I had them removed about two weeks ago when I replaced the rear speakers...perhaps I've hit something and disconnected it...
Old 02-10-2010, 07:55 AM   #5
Thats the amplified antenna box.
It will boost the signal received by the antenna in the glass.
It needs to be hooked in properly up front also, switched 12V.
